Krose Posted December 23, 2013 Share Posted December 23, 2013 Not every time but usually when engine cold, the car starts fine but the display resets itself like is some sort of test with the fuel guage going from zero to full, and rev counter shows zero then everything goes to normal. Might also be linked but am getting intermittent fault where passenger door will not lock via remote or manual locking drivers side. If i lock manual on passenger door then all is ok. Have changed battery in keyfob and no difference Any ideas? am not overly concerned about locking as can manually do it but the reset/reboot of display is a concern Just to confirm the car starts and drives ok Quote Link to comment Share on other sites More sharing options...
btmaldon Posted December 23, 2013 Share Posted December 23, 2013 The sweeping dials and check process normally indicates that the battery is on its way out. All remaining power is being utilised to start the car causing the instrument cluster to go through a test routine. You can normally get a battery check done for free. Just make sure you get a silver calcium battery as lead acid batteries cannot handle the Ford Smart Charge system. Quote Link to comment Share on other sites More sharing options...
Krose Posted December 23, 2013 Author Share Posted December 23, 2013 Thx will go get battery checked in morning Quote Link to comment Share on other sites More sharing options...
Nathan_M Posted December 24, 2013 Share Posted December 24, 2013 If its the same as my fiesta last year then the battery is on its way out, all the clocks and displays should stay alive when starting the engine albeit a little dim while cranking, and as for the door locking thing the fiesta/fusion door design is poor with water, it runs through the door and with heavy rain mine has a little hiccup every so often if Un used for a day, you could try using some wd40 and it's straw and blow some through the locks both external and internal this should help the water to skirt around the electrical bits that matter. Sent from my GT-N5110 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted December 24, 2013 Share Posted December 24, 2013 Agree with the battery issue unfortunately! Quote Link to comment Share on other sites More sharing options...
Krose Posted January 19, 2014 Author Share Posted January 19, 2014 Finaly to reply, i delayed doing anything over holiday period and although problem persisted the car always started. Finaly got battery checked, dunno how this relates but reading was 232 mah when battery sticker said should be 320mah. New battery now in, a lot higher rating 450mah and no problems as yet Thx for advice Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted January 21, 2014 Share Posted January 21, 2014 glad its sorted! Quote Link to comment Share on other sites More sharing options...
