spelly Posted December 23, 2013 Share Posted December 23, 2013 Issues over last few winters, engine cuts out and dies, electrics all seem fine, stand for 5-10 mins and then runs normally with engine warning light on, after a day or two of use engine warning light goes out. garages have looked at it but find nothing, have switched from generic cheap diesel to branded, have tried redex diesel additives but still happening any ideas vehicle is 2007, 5sp manual 2.5 TD, no mods, 86000 miles, annual garage serviced never done it in summer, always when ambient temp below 4-5 deg c Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted December 24, 2013 Share Posted December 24, 2013 When was the last service? I had this issue and it was a fault with the fuel filter. Quote Link to comment Share on other sites More sharing options...
spelly Posted December 25, 2013 Author Share Posted December 25, 2013 recent service - did it again crimbo eve heading home, could make it cut out by hard acceleration so maybe fuel pump or injectors ?? Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted December 26, 2013 Share Posted December 26, 2013 Sounds like the fuel filter has been installed incorrectly? It sounds to me like air has gotten into the fuel, as the cold contracts the metal opening up a hairline crack or any space somewhere, this then draws air in with the pressure on the inside of the pipe drawing it in. The air then gets injected to the engine and cutting it out... I would say this is the easiest place to start, but it could be the housing itself? 1 Quote Link to comment Share on other sites More sharing options...
spelly Posted December 26, 2013 Author Share Posted December 26, 2013 Certain logic to that - will try and explore that one. Sadly I am no mechanic but will see what garage say to that idea. Thanks for your input Quote Link to comment Share on other sites More sharing options...
