Ford Focus Tdci 1.8 Injector Problems
injector start up failure
114 replies to this topic
#31 mick85
mick85
  • True Ford Enthusiast
  • 924 posts
Posted 03 January 2014 - 10:57 PM
U have egr blanked off and still have it connected did u try starting car wit egr completely romoved
Have something to contribute?
#32 Chinny
Chinny
  • Budding Enthusiast
  • 37 posts
  • Name: Craig
  • Ford Model: Focus
  • Year: 2006
Posted 03 January 2014 - 11:31 PM
I would check egr make sure it's operating as it should
#33 kylet1990
kylet1990
  • 69 posts
  • Name: kyle
  • Ford Model: focus tdci 1.8
  • Year: 2002
Posted 03 January 2014 - 11:35 PM
No i havnt tried that yet as ive been at work. I will tomorow and see if it will start with the egr unplugged. Im starting to question if the reconditioned injectors i bought are no good.
#34 kylet1990
kylet1990
  • 69 posts
  • Name: kyle
  • Year: 2002
Posted 04 January 2014 - 06:46 PM
I disconnect the egr valve plug and the popping noise stopped and when it hit 2000rpm driving the coil light did come on and it went into limp move but it didnt cut out. Also it was throwing massive amounts of smoke out the back.
#35 kylet1990
kylet1990
  • 69 posts
  • Name: kyle
  • Year: 2002
Posted 04 January 2014 - 06:55 PM
Is there any way of opening the fuel filter to check for shards of metal off the pump?
#36 mick85
mick85
  • 924 posts
Posted 04 January 2014 - 06:58 PM
Is yours plastic housing paper filter yeah u can check it
#37 kylet1990
kylet1990
  • 69 posts
  • Name: kyle
  • Year: 2002
Posted 04 January 2014 - 07:07 PM
Its a sealed metal filter with a screw on bleeder valve type thing on the bottom. I emptied it out a bit of black gunk stuff came out but no metal shavings.
#38 mick85
mick85
  • 924 posts
Posted 04 January 2014 - 07:40 PM
U would have to cut it in half then when u last replace it
#39 kylet1990
kylet1990
  • 69 posts
  • Name: kyle
  • Year: 2002
Posted 04 January 2014 - 07:41 PM
Ive never replaced it but bought the car 5 months ago
#40 Chinny
Chinny
  • 37 posts
  • Name: Craig
  • Ford Model: Focus
  • Year: 2006
Posted 04 January 2014 - 07:56 PM
It would of gone into limp mode as the erg has been unplugged, I would blank erg valve off and reconnect plug should be fine after that
#41 mick85
mick85
  • 924 posts
Posted 04 January 2014 - 07:58 PM
For wat filter would cost I would defo replace it least u can rule out as a problem
#42 kylet1990
kylet1990
  • 69 posts
  • Name: kyle
  • Year: 2002
Posted 04 January 2014 - 07:59 PM
I have blanked it off. I put a blanking plate inbetween the egr valve and the pipe that goes to the exhaust manifold.
#43 Chinny
Chinny
  • 37 posts
  • Name: Craig
  • Ford Model: Focus
  • Year: 2006
Posted 04 January 2014 - 08:00 PM
Sounds like erg is stuck open and choking engine, you could remove egr and inlet manifold clean all the black gunk with carb clean make sure egr is operating manually after clean then put it back together
#44 kylet1990
kylet1990
  • 69 posts
  • Name: kyle
  • Year: 2002
Posted 04 January 2014 - 08:02 PM
How big of a job is it to remove the egr valve? It looks mounted to the inlet manifold.
#45 Chinny
Chinny
  • 37 posts
  • Name: Craig
  • Ford Model: Focus
  • Year: 2006
Posted 04 January 2014 - 08:05 PM
Not to bad I would take the manifold off as well clean it all as the gunk can build up inside the inlet manifold reducing the airflow
Not what you're looking for?
Also tagged with one or more of these keywords: injector, start up failure
