josrey
1.4Tdci 2010 Fiesta Running Rough And Smoking On Start??
7 posts in this topic
Got a 2010 mk7 fiesta and it's running rough and smoking on start up garage said it could either injector 3 not working or a bent conrod has anyone had any experience of this or can help on the matter as I do t wanna fork out £2k if it's the conrod
thanks in advance
Sounds like a leaking injector to me.
Fuel pooling in the cylinder when off would cause smoke and roughness until burned off.
Thanks a lot that is what I wanted to hear really don't wanna send £2k on a new engine!!
Agree with Stoney wats ur mileage also might be worth checking glow plugs they could be gone as well an making symptoms worse
Mileage is only 48k so not done a million miles and I will check the glow plugs anything that can cure this will be good :)
Well they very easy to test but u are ment change every few years an don't think they the handiest to change so if u not stuck for cash I would replace could prevent further problems down the line
Update on this issue its not the injector it was sent off to a diesel injector specialist and they have said its working fine head is coming off as i write this!!
