ktt Posted December 30, 2013 Share Posted December 30, 2013 Could someone instruct how to remove (without extra damage) front right interior door handle? The door handle axle's lower hinge is broken thus the "handle module" needs to be replaced. But the problem is, I can't remove the black disk on bottom of interior door handle module. I tried to carefully remove it using pliers but no luck, it just slipped. How should that be removed? And the next question, how is the cable going towards lock removed? Based on pictures on eBay, the cable and interior handle module seem to be one unit, but some places are selling also plain interior handle modules without cable. Thanks, Kalle from Turku, Finland Quote Link to comment Share on other sites More sharing options...
ktt Posted December 30, 2013 Author Share Posted December 30, 2013 Answering to myself. The answer was here: http://fordtransit.org/forum/viewtopic.php?f=54&t=58723#p507903 One just needs to pull handle module away - the black disk will come away easily. And after the handle module was removed, the wire was also easy to remove. So question is closed. Quote Link to comment Share on other sites More sharing options...
