MONDEO-FAMILY
Mk3 Front Wheel Bearing
3 posts in this topic
please can people help can any one tell me what sort of noise a worn Wheel Bearing would give as I have a very loud humming noise at about 40 mph and as I go faster the noise speeds up but does not change when clutch is disengaged and the engine sounds do not change :rolleyes:
jack ya car up and shake ur wheel side to side up and down, this will tell you if its fooked or not
What he said. The other option that springs to mind is a worn cv joint.
A shot wheelbearing generally sounds like a low-pitched grinding noise/rumble, and you might find that it gets worse/better if you steer left or right.
