makalu Posted January 5, 2014 Share Posted January 5, 2014 Hi Fellow SMax Pilots. Decided to join the forum after lurking for a while. I have a 2008 SMax 2.0 Titanium Diesel (140PS) and generally speaking its been a great family car. However yesterday the parking brake decided to jam in the fully up and engaged position (its a manual brake not electric). Despite my uneducated attempts to release it, it was not budging. AA called out and the sourced the problem to a broken release cable in the handle. There is a small flat 'S' shaped (or 'kinked') end to the button release cable that seems to go up inside the handbrake handle's driver's side arm and I think this connects to the spring loaded button in the handle at the top. This 'S' shaped part has broken leaving the spring loaded release button permanently engaged. The nice AA man left me with a piece of wire connected to the release cable which we can now pull on to disengage the button release lock - so at least we have a 'get you home' fix. I started searching the web to see if there is a replacement cable. Looks like you can buy either an entire handbrake assembly (£160...) or just a replacement handle (£60) - all because of a simple broken cable! The handle option does not appear to include a cable, the full assembly does (at least the pictures on eBay suggest this is so). Has anyone else had this problem and what is the best way to fix it? Do I need an entire assembly (like this -> Link) or is there a way to replace just the cable? Thanks for any help offered! Mak. Quote Link to comment Share on other sites More sharing options...
gregers Posted January 5, 2014 Share Posted January 5, 2014 soz cant offer you any practical advice on a fix,but why not pm any eBay sellers who are breaking an smax for the part.im sure they could be a hell of a lot cheaper?? Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted January 6, 2014 Share Posted January 6, 2014 Im not sure which part you are referring to to be honest, but it does sound like it should be at the base of the handbrake, in which case a trip to the breakers should help you for a lot less money! Quote Link to comment Share on other sites More sharing options...
Steve1305 Posted April 6, 2014 Share Posted April 6, 2014 I had exactly the same last June on my 1800 Tdci Zetec (2007) and again the AA had to do me a Heath Robinson botch till I got to the garage - £200 for a new Unit. Bizarrely it went again this month though apparently this time it was a calliper that needed adjusted and the handbrake cable also adjusted. Horrible design and gives no confidence now Quote Link to comment Share on other sites More sharing options...
fastvelz Posted March 21, 2015 Share Posted March 21, 2015 Hi, I got exactly the same problem and fixed it at home for a few pence. You cannot buy the little release cable as a separate part, but a piece of " tiger tail" wire from the craft shop does the same job. Whatever wire you choose it has to be pretty thin to go round the nylon wheel at the bottom of the right HB arm. How? Unscrew the box out of the central console. (Torx screws). Next pull up the chrome trim with the cup holder and slip the gaiter off the gearstick. Now prise off the chrome looking plastic around the release button and next pull out the button and mechanism. Not much more now....unhook the broken wire from the button and the ratchet and pull free. Feed the tigertail wire through the handle and tie onto the button. (I used a wd40 straw around the bend to avoid it rubbing to bits again). Lastly feed it round the nylon wheel and tie it to the hole in the ratchet mechanism. Done. Just the plastics to be put back on in reverse order. Hope you too can benefit from this cheap workaround if you hit the same problem. Edit: after one year the tigertail wire also failed, so I now spent a full £1 on proper guitar string. The cost is mounting!! 3 Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted March 22, 2015 Share Posted March 22, 2015 An excellent suggestion! 1 Quote Link to comment Share on other sites More sharing options...
gregers Posted March 22, 2015 Share Posted March 22, 2015 great info. 1 Quote Link to comment Share on other sites More sharing options...
747777 Posted March 24, 2015 Share Posted March 24, 2015 Very useful info, thank you. 1 Quote Link to comment Share on other sites More sharing options...
shorehamford Posted April 27, 2015 Share Posted April 27, 2015 Fantastic suggestion. I used 0.38mm tiger tail wire and the handbrake now works properly for the first time in months. 1 Quote Link to comment Share on other sites More sharing options...
gingerford Posted December 9, 2015 Share Posted December 9, 2015 Hi, I got exactly the same problem and fixed it at home for a few pence. You cannot buy the little release cable as a separate part, but a piece of " tiger tail" wire from the craft shop does the same job. Whatever wire you choose it has to be pretty thin to go round the nylon wheel at the bottom of the right HB arm. How? Unscrew the box out of the central console. (Torx screws). Next pull up the chrome trim with the cup holder and slip the gaiter off the gearstick. Now prise off the chrome looking plastic around the release button and next pull out the button and mechanism. Not much more now....unhook the broken wire from the button and the ratchet and pull free. Feed the tigertail wire through the handle and tie onto the button. (I used a wd40 straw around the bend to avoid it rubbing to bits again). Lastly feed it round the nylon wheel and tie it to the hole in the ratchet mechanism. Done. Just the plastics to be put back on in reverse order. Hope you too can benefit from this cheap workaround if you hit the same problem. Edit: after one year the tigertail wire also failed, so I now spent a full £1 on proper guitar string. The cost is mounting!! 2015-11-18_22.04.54.jpg2015-11-18_22.12.50.jpg2015-11-18_22.09.27.jpg Quote Link to comment Share on other sites More sharing options...
gingerford Posted December 9, 2015 Share Posted December 9, 2015 I used guitar string to fix mine. excellent solution. however I could not manage to take out the release button to extract the broken cable. the cable was broken at the base exactly where the ratchet release was. we looped the guitar string through the that ratchet and connected the new cable to the original one with a small pliers. works perfect. Small hands required! Quote Link to comment Share on other sites More sharing options...
MikeTheTv Posted January 3, 2016 Share Posted January 3, 2016 Hi, I got exactly the same problem and fixed it at home for a few pence. You cannot buy the little release cable as a separate part, but a piece of " tiger tail" wire from the craft shop does the same job. Whatever wire you choose it has to be pretty thin to go round the nylon wheel at the bottom of the right HB arm. How? Unscrew the box out of the central console. (Torx screws). Next pull up the chrome trim with the cup holder and slip the gaiter off the gearstick. Now prise off the chrome looking plastic around the release button and next pull out the button and mechanism. Not much more now....unhook the broken wire from the button and the ratchet and pull free. Feed the tigertail wire through the handle and tie onto the button. (I used a wd40 straw around the bend to avoid it rubbing to bits again). Lastly feed it round the nylon wheel and tie it to the hole in the ratchet mechanism. Done. Just the plastics to be put back on in reverse order. Hope you too can benefit from this cheap workaround if you hit the same problem. Edit: after one year the tigertail wire also failed, so I now spent a full £1 on proper guitar string. The cost is mounting!! Exactly the same problem happened on our S-Max recently, the thin wire release cable broke about 1" from the button just where the cable goes over the 90 degree sharp bend from the horizontal handle to the vertical handbrake arm. I'm no mechanical engineer but I can figure out that if you allow a thin wire cable to move back and forth over a sharp bend it's going to break there sooner or later. And then to not stock it as a separate spare but instead force you to Shell out £150+ for the entire handbrake mechanism, poor show Ford!! Anyway enough of the complaining, I thought I would share my fix to this problem as this thread inspired me to do-it-myself. Firstly the original wire cable is 0.83mm diameter. I think it's a 7x7 strand arrangement, that is 7 individual wires wound together into a single strand, which is then wound with 6 other strands to form the final cable. The cable has a T-bar stop on one end and a cranked hook on the other. The visible cable length between these two ends is exactly 40cm. Initially I looked at making an entirely new cable from scratch, however I could not find anywhere that sold crimpable T-bar ends, and in any case the cranked hook end was going to be difficult. Instead I decided to keep the cranked hook end and splice on a new length of wire cable and make a replacement T-bar end. All the bits I needed came from a company called TecniCable and are listed below (prices ex VAT and ex P&P): 0.9mm 7x7 wire cable (603.000.900) quantity 1m - £0.84/m 1mm A4-AISI 316 Stainless Steel Thin Walled Stop (208.606.010) quantity 1 - £1.13ea 1mm Double Copper Ferrule for 0.9-1.0mm cable (115.000.010) quantity 3 - £0.24ea The 0.9mm 7x7 wire cable is slightly larger diameter than the original but is still very flexible. I did try a 1.0mm cable but decided not to use it in the end as although it was still very flexible, its bend radius was a bit much for the edge it needs to go over in the handbrake assembly. The 1mm stainless steel thin walled stop I used was exactly the same size as the original cables T-bar end and so slipped into the hole in the plastic button perfectly. This should help spread the load from the cable and prevent the cable wearing through the plastic. The double copper ferrules are like a figure of 8 end on and allow you to splice two cables together or terminate a cable with a looped end. You can buy proper crimping tools for these ferrules but a good pair of pliers or mole grips works just as well. NOTE: I did mess up the first couple of attempts so you may want to buy say 2m of the cable and maybe 9-10 ferrules just in case. OK to fix the cable you need to do the following: Disassemble the centre console until you can reach into the handbrake mechanism. fastvelz gave some details. In the end I removed the whole thing to get better access, but that was quite time consuming and hard work. Remove the old release cable. The cranked hook end is a bit tricky to remove as the up-cranked bit fits up between the underside of the U shaped bar which forms the bottom of the handbrake leaver. At the end near the ratchet (see fastvelz second image) the U bar is open bottomed, further back its a closed U. Thread some fine string or fishing line down the vertical arm of the handbrake on the drivers side where the release cable went, this just makes it easier later to thread the new wire cable through. Cut off the cranked hook end leaving about 5-6cm of the original wire. Sorry I can't be more precise but I forgot exactly what length I left. Originally I made it too long and found the crimp ferrules connecting the old and new wire cables together got caught at the other end of the U shaped bar the cable slides in near the nylon wheel. This end is again open bottomed which formed an edge the ferrules got caught on. Take the length of new cable and thread one copper ferrule over the end, then the stainless steel thin walled stop and finally feed the end back through the ferrule again. Leave some spare cable but do not crimp this end yet. Gently squeeze the loop of wire which goes through the steel stop to form a tight loop. This should leave a bit of a bend in the cable where the steel stop fits, as this end has to be crimped in place and you can't remeasure where this bit goes. Slide another two copper ferrules onto the other end of the new cable and then slide the old hook end cable through the other half of the ferrules. Lay out the old and new cable on top of a tape measure and adjust it such that the distance between the steel stop forming the T-bar end and the point the old cable is formed into the hook end is exactly 40cm. The two copper ferrules at the hook end should be next to each other and at the end of the tail of wire left on the hook end. I used two ferrules here to be more secure with the in-line join. Squeeze the two ferrules around the old and new wire cable at the hook end. I used a pair of mole grips to squeeze each each channel through the figure of 8 shape. Carefully test the join and squeeze tighter if needed. Don't absolutely flatten the wire by over squeezing as this will splay the wire end and make it difficult to remake if you mess it up. Cut off any excess new cable sticking out of the ferrules. Recheck the length and adjust the loop of wire at the T-bar end if necessary. Remove the steel stop and ferrule from the T-bar end as you can't thread this up through the handbrake handle. Hopefully the cable will have a couple of kinks in it where the steel stop goes so its obvious when it comes to putting these bits back as you can't measure it once it's in place. Now thread the unfinished end of the wire into the U shaped channel of handbrake mechanism from the ratchet end towards the nylon wheel. The wire must be in this channel not underneath it, I made that mistake the first time. Then fit the hook back through the hole in the ratchet making sure the up-cranked part of the hook fits up into the U channel. Take the wire around the nylon wheel and then up through the vertical handle of the handbrake. This is where having a fish wire may be useful. Once the wire cable comes out at the top of the handbrake lever thread on the ferrule, then the stainless steel stop. Before threading the cable back through the ferrule again pass the stainless steel stop through the hole in the button where the T-bar would have gone, then thread it through the ferrule to close the loop. This will effectively trap the button in the loop. Close the loop fairly small by sliding the ferrule closer to the stainless steel stop where it passes through the button. There is a post on the underside of the button behind the T-bar hole towards the end you press, you want to end up with the ferrule between that and the T-bar hole so it's out of the way. Crimp the ferrule on the loop tight and snip off any excess so it fits in the gap. Finally put the spring back on the button end and feed it into the handle. Then put the centre console back together. I hope this proves some help to others. Quote Link to comment Share on other sites More sharing options...
Shooey Posted June 7, 2018 Share Posted June 7, 2018 I have this problem now but i cant afford to replace the handbrake (including labour about £200+). I dont have the expertise to do the job shown previously. I'm just wondering if i can use a local mechanic to get the cable changed, using the one here on eBay (https://www.ebay.co.uk/itm/232462484460?ul_noapp=true) or this one (https://www.ebay.co.uk/itm/311535777979?ul_noapp=true)? Quote Link to comment Share on other sites More sharing options...
PSYCHONAUT Posted September 10, 2018 Share Posted September 10, 2018 hi guys, thought i would add my 2 penneth worth. same problem, snapped cable. i couldn't get it to work with one guitar string ( excellent idea by the way! thanks fastvelz). i couldn't tie a knot tight enough and keep the tension on the string at the same time. there's very little room to do it! i used 2 guitar strings so the strings have a brass ring at one end (with a hole through the middle). at the top, take one string and use the brass ring to anchor it in the plastic handle (you have to bend the string into the recepticle so that the brass ring pokes out sideways as it wont sit in the actual hole where the old one sat as its too big, but it will make it fast). then poke the end of the string down through the handle to the bottom. put the handle back together again. then get the second string, and feed it round the metal loop at the bottom (the one that pulls the tooth out of the cog) and loop it through itself (through the hole in the brass ring) and pull tight. now you have the two anchored ends, and two free ends to attach together. i used a chocolate block electrical connector. feed the two free ends through in opposite directions, pull tight with pliers and then tighten the screws. very fiddly, you will need 4 hands, but seems to be ok so far. having thought about it, i should have used 2 chocolate blocks instead of one , leaving them attached to each other by the plastic bonds that they already have, side by side, then i could have put one string into one side, and the other into the other side, and independently pulled each string tight as opposed to having to pull both tight at the same time ...probably would have been easier, and probably stronger . i haven't tested this properly yet, only did it tonight but i can now operate my handbrake ....for how long, i'm not sure but i will report back if it fails. Quote Link to comment Share on other sites More sharing options...
PSYCHONAUT Posted September 10, 2018 Share Posted September 10, 2018 Quote I have this problem now but i cant afford to replace the handbrake (including labour about £200+). I dont have the expertise to do the job shown previously. I'm just wondering if i can use a local mechanic to get the cable changed, using the one here on ebay (https://www.ebay.co.uk/itm/232462484460?ul_noapp=true) or this one (https://www.ebay.co.uk/itm/311535777979?ul_noapp=true)? by the way shooey, the links you posted are not the right cable, they are actually the handbrake cable to the wheels. Quote Link to comment Share on other sites More sharing options...
PSYCHONAUT Posted November 5, 2018 Share Posted November 5, 2018 my guitar string technique failed again. i have now found this, a replacement oem cable from x8r, they've only just started selling these, and they onyl sell them on eBay. £35 https://www.ebay.co.uk/itm/Ford-S-Max-Galaxy-Handbrake-Lever-Release-Button-Parking-Hand-Park-Brake-Cable/232990582324?hash=item363f522634:g:2WUAAOSwwDJb3FX9:rk:3:pf:0 ive just ordered one, will let you know how it goes. Quote Link to comment Share on other sites More sharing options...
PSYCHONAUT Posted November 17, 2018 Share Posted November 17, 2018 Jjust fitted it today. seems fine. the BEST thing is that you do NOT need to remove the whole handbrake assembly from the car. you don't need to get underneath. remove all trim as per this video https://www.youtube.com/watch?v=JoWTgtkIzX0&t=530s then you can fit this (look at this video https://www.youtube.com/watch?v=N56FtsM8Yy4 you will see my post about it there as well). top tip is to use a paperclip to grab the cable as it comes down the handle so that you can pull the cable out and then around the plastic wheel. make a hook with the paperclip, insert into the handle just above the plastic wheel. feed the cable down the handle until some of it has come out the bottom of the handle. hopefully you have caught the cable in your paperclip hook,...hold the bit that came out of the bottom, and pull the paperclip out and bingo! if not, rinse and repeat. YOU WILL NEVER GET THE CABLE THROUGH THE CORRECT SIDE OTHERWISE (unless you take the whole assembly out). its a bit tight up against the lower plastic trim when you come to tighten the bolt through the hole, but just bend it....i managed to get a socket in between the trim and the bolt (make sure you have removed the plastic bush in the hole if its in there otherwise you will never get the bolt in!). make sure you test it before refitting trim. i had mine too tight at first and it prevented the handbrake from latching. red arrow in attached jpeg shows where to shove in paperclip took about an hour all in. Quote Link to comment Share on other sites More sharing options...
MjMadd Posted September 20, 2019 Share Posted September 20, 2019 I have just had this happen and while I realise this thread is very old. Clearly this is a cash cow for ford as the design is ridiculous and after much digging happens a great deal. I too was told I needed to replace the whole assembly as ford doesn't just sell the actual cables. Thankfully I came across a company that does https://x8r.co.uk/ford-s-max-galaxy-handbrake-lever-release-button-parking-hand-park-brake-cable I ordered it and it is very easy to install. I used a longer screw than what came with the cable as I didn't want to take the whole unit out as they suggest to do this job and it made my life easier as it is fiddly to get in there. The design makes a great deal more sense too getting rid of that ridiculous S connector to create a far more durable and hopefully long lasting part. Time will tell but so far so good. I also see @PSYCHONAUT above has used this too. Highly recommend Quote Link to comment Share on other sites More sharing options...
tallrob Posted February 27, 2020 Share Posted February 27, 2020 I'm raising all kinds of zombie threads from the dead lately. I have a snapped/missing cable on a recently purchased 2007 S-Max, but the brake itself doesn't set – the opposite problem many have who find their brake won't release. So my problem is complex. Before I tear into it I thought I'd ask if anyone else experienced this. If I roll the car a bit and pull the brake, it stops the car, so I know the cables are attached, but it seems like the ratchet mechanism isn't catching at all. Could be whoever got the brake unstuck actually buggered the whole thing. Quote Link to comment Share on other sites More sharing options...
