murrmaca
Alarm System Service
19 posts in this topic
Hi looking for some advice or help the alarm system service warning has appeared on the display. what can cause this ?
is there a way to reset this or does it need to go to a ford dealer ?
many thanks in advance
Fiona
Hi update done some research found someone talking about a back up battery for a back up alarm located in the wheel arch confused ??? Help !
apparently there is a known fault about this.iirc it gets water logged?and looks like a new 1 needs to be fitted??
Cheers gregers
got in car today alarm system thing not coming up on display
could you tell me where to locate this alarm so I can try and water proof it before any more damage caused
Many thanks
Fiona
Start by checking the fuseboard in the passenger side, and the engine bay, make sure they are not soaked through, if so, dry them with a hairdryer...
Next time it's dry and wind not so high I will have a look thanks !
iirc its found under the passenger wheel arch lining??
Many thanks will look
Thanks for all the help and advice
Fiona
no probs fi.
Help needed again bonnet will not close stupid thing was working fine till I filled up with water
many thanks
Fiona
You will need the bonnet release cable & catch replacing. Common issue on the early S-maxes - the cable is very poorly designed and rusts internally so it does not open & close properly, and the routing around the catch exacerbates the issue.
The replacement parts are of a different design - but beware, there is about 2-3 hours labour involved in this job so it's not a cheap fix.
Got a catch from a ford dealer on eBay looks like it's right part, didn't think I would need the cable. Would it b sensible to replace this too?
Fiona
From what I have read you HAVE to replace the cable to fix this fault.
you might be able to salvage it,aslong as it hasnt broken??.
remove the cable hang it up and keep dripping penetrating oil down the sleeve?
As far as I'm aware cable ok it released the catch. Thanks will defo try that!
Thanks Fiona
You will need a new cable. The old cable is not compatible with the redesigned catch.
Greggers advice makes no sense whatsoever. Why would you spend 3 hours removing, cleaning & refitting a cable when a new one is about £30.
you are quite correct,cripes 3 hours!nice straight foreward job then :o ,i know peeps have done this on the galaxy before but this was without buying anything.basically they were trying to nurse/make good what they had.
I'm so confused now !! Think I will nip car in to my local garage and c what they say, but will keep all advice in mind and may even quote it to garage
Thanks Fiona
New catch fitted cable was a little seized but ok now thanks for all the advice
Fiona
