Bluetooth Install Guide?
91 replies to this topic
#31 GothicRebel
GothicRebel
    Rogue Southerner Lost in Sheffield
  • Budding Enthusiast
  • 226 posts
  • Name: Andy
  • Ford Model: Focus Titanium Black
  • Year: 2009
Posted 10 January 2014 - 07:20 AM
200 for everything? Was that from ford?
If so all I need is the loom.
Was it easy to install?
Have something to contribute?
#32 higgsy
higgsy
    Northern Yam Yam
  • 835 posts
  • Name: James
  • Ford Model: Focus Zetec S 1.6 TI-VCT
Posted 10 January 2014 - 07:40 AM
When I say everything that is the retrofit loom/module/mic/USB cable and some other little bits in that kit. I will just route the USB into the glove or get a socket that goes next to the heated screen switches prob just the glove tho as means I don't have to spend any more cash! I basically lost patience with the search to be fair and worked out if anything once I had sourced the bits separately it would save me maybe 50 at the most - not worth my time and hassle to be fair, if I had the wiring I would have deffo gone down the scrappy/ eBay route.
Getting the kit delivered today so hope to fit tomorrow weather permitting.
Should just be:
Remove stereo to fit loom
Remove glove to fit module
Route loom behind glove/connect
Route USB into glove
Install mic and run cable down the passenger a pillar and connect
Refit all
Update software
I reckon about an hour or so to do.
Search novero ford retrofit on Google and you will see the kit.
Sent from my Nexus 5 using Ford OC mobile app
#33 GothicRebel
GothicRebel
  • 226 posts
  • Name: Andy
  • Year: 2009
Posted 10 January 2014 - 07:47 AM
I wonder if I can just get the main loom.
When it arrives could you take detailed pics of it all. Personally I'd love to see both ends of the loom that connects to the Bluetooth. And the other end of the mic loom.
And one of the back of your stereo. If you wouldn't mind?
Hopefully like you. Should be an easy job if I can get a loom. As my old man pics my bits up from
The scrappy today
#34 higgsy
higgsy
    Northern Yam Yam
  • 835 posts
  • Name: James
Posted 10 January 2014 - 07:52 AM
I will be taking some pics so I can put an update in my timeline thread. I will also take some of the kit / plugs before install and post back here when done. No probs.
#35 GothicRebel
GothicRebel
  • 226 posts
  • Name: Andy
  • Year: 2009
Posted 10 January 2014 - 07:56 AM
Thank you very much.
#36 Focus-Jonny
Focus-Jonny
    Heresss Jonny!!!!!
  • 338 posts
  • Name: Jonathan
  • Ford Model: Ford Focus Mk2.5 Zetec S 1.6 Ti-vct
Posted 10 January 2014 - 12:02 PM
Im interested in the novero kit also so please keep us updated on your experience with the kit! Can you use bluetooth a2dp? And control iPod from the head unit with full track info if connected via usb?
#37 jamesm182
jamesm182
    Management
  • Admin
  • 1,447 posts
  • Name: James
Posted 10 January 2014 - 12:45 PM
Yes you can using the proper ford Bluetooth/voice control/USB kit. iPod info comes up and A2DP streaming is available and also gives the track name on my Sony unit.
#38 Focus-Jonny
Focus-Jonny
    Heresss Jonny!!!!!
  • 338 posts
  • Name: Jonathan
Posted 10 January 2014 - 01:05 PM
Happy days! Thanks mate this is good news for those like me that don't have the loom in place! Just need to purchase a sony head unit first pref 2010-11 version so i can guarantee latest firmware!
#39 higgsy
higgsy
    Northern Yam Yam
  • 835 posts
  • Name: James
Posted 10 January 2014 - 01:09 PM
What James said. I will post my experiences. Its arrived but I'm at work :-(
#40 jamesm182
jamesm182
    Management
  • Admin
  • 1,447 posts
  • Name: James
Posted 10 January 2014 - 01:16 PM
My car is a 2008 and my software was still new enough to accept USB (and then update to the latest one).
I think the cut off was sometime in early 2008 though as there are people with early Sony units that do not accept USB.
#41 GothicRebel
GothicRebel
  • 226 posts
  • Name: Andy
  • Year: 2009
Posted 10 January 2014 - 01:17 PM
Had another good look.
Can't see it anywhere.
This is the back of my sony head unit.
Where does the plug and play kit loom fix into the radio?
#42 GothicRebel
GothicRebel
  • 226 posts
  • Name: Andy
  • Year: 2009
Posted 10 January 2014 - 01:30 PM
I think I've just found the grey connector block. I think Gav said it's for the mic?
Passenger side door trim level to the wing mirror
#43 JW1982
JW1982
  • True Ford Enthusiast
  • 796 posts
  • Name: Wilco
  • Ford Model: Focus MK3 Champions Edition
  • Year: 2013
Posted 10 January 2014 - 01:46 PM
The retrofit wiring loom is connected between the radio and the Quadlock (radio connector). It is not connected to the radio directly. The other end of the cable is attached to the microphone connector and the Bluetooth/voicecontrol connector. This wiring loom costs approximately €135,- from Ford.
#44 GothicRebel
GothicRebel
  • 226 posts
  • Name: Andy
  • Year: 2009
Posted 10 January 2014 - 01:57 PM
The retrofit wiring loom is connected between the radio and the Quadlock (radio connector). It is not connected to the radio directly. The other end of the cable is attached to the microphone connector and the Bluetooth/voicecontrol connector. This wiring loom costs approximately €135,- from Ford.BT-VCkabel.jpg
Do you happen to know the UK ford part number for the loom im missing?
#45 GothicRebel
GothicRebel
  • 226 posts
  • Name: Andy
  • Year: 2009
Posted 10 January 2014 - 04:18 PM
Ok I followed the mic loom
This afternoon after seeing the grey block in the passenger pillar. After the grey block the wire then goes to this grey pipe visible wires head to the center dash and the pipe goes down and opens up again at the passenger footwell. Then heads to the rear of the car. Rear speakers?
Not what you're looking for?
