Bluetooth Install Guide?
91 replies to this topic
#46 higgsy
higgsy
    Northern Yam Yam
  • 831 posts
  • Name: James
  • Ford Model: Focus Zetec S 1.6 TI-VCT
Posted 10 January 2014 - 04:32 PM
The retrofit wiring loom is connected between the radio and the Quadlock (radio connector). It is not connected to the radio directly. The other end of the cable is attached to the microphone connector and the Bluetooth/voicecontrol connector. This wiring loom costs approximately €135,- from Ford.
€135? Is that a typo?
Sent from my Nexus 5 using Ford OC mobile app
Have something to contribute?
#47 JW1982
JW1982
  • True Ford Enthusiast
  • 565 posts
  • Name: Wilco
  • Ford Model: Focus MK3 Champions Edition
  • Year: 2013
Posted 10 January 2014 - 04:54 PM
No, unfortunately not.
From Ford the complete retrofit kit costs about €500,- and the seperate parts which are included in the kit are also expensive.
I bought all Bluetooth/Voicecontrol parts from a local scrapyard for less than €40,-. I made the wiring loom myself using an interior wiring loom from a scrap Focus MK2.5.
#48 higgsy
higgsy
    Northern Yam Yam
  • 831 posts
  • Name: James
Posted 10 January 2014 - 05:52 PM
Wow steep, makes my 200 kit cheap as chips!
Here's a link to pics of the kit. Let me know if you need owt else
http://www.fordowner...ead#entry320090
#49 Focus-Jonny
Focus-Jonny
    Heresss Jonny!!!!!
  • Budding Enthusiast
  • 338 posts
  • Name: Jonathan
  • Ford Model: Ford Focus Mk2.5 Zetec S 1.6 Ti-vct
Posted 10 January 2014 - 07:16 PM
Keep us up to date on the fitting! Looks good!
#50 higgsy
higgsy
    Northern Yam Yam
  • 831 posts
  • Name: James
Posted 11 January 2014 - 10:08 AM
Fitted the kit and all working fine! Took about an hour. Very easy. Funny thing was I found the module connector but I deffo had no mic going in to the roof lining. The retrofit kit kit just makes it so easy. I will be posting some pics later in my thread ( not really that much to say to be honest)
#51 GothicRebel
GothicRebel
    Rogue Southerner Lost in Sheffield
  • 226 posts
  • Name: Andy
  • Ford Model: Focus Titanium Black
  • Year: 2009
Posted 11 January 2014 - 10:09 AM
Where was your connector Higgsy ?
#52 higgsy
higgsy
    Northern Yam Yam
  • 831 posts
  • Name: James
Posted 11 January 2014 - 10:37 AM
Taped up on the left hand side right next to the opening of the glovebox hole
#53 higgsy
higgsy
    Northern Yam Yam
  • 831 posts
  • Name: James
Posted 11 January 2014 - 01:17 PM
Updated my thread with details of the retrofit kit install
http://www.fordowner...ead#entry320279
#54 GothicRebel
GothicRebel
  • 226 posts
  • Name: Andy
  • Year: 2009
Posted 13 January 2014 - 10:25 AM
Anyone know if the Bluetooth VC USB module ending in AP would work ok? Ordering in the retrofit cable in about ten mins.
#55 jamesm182
jamesm182
    Management
  • Admin
  • 1,405 posts
  • Name: James
Posted 13 January 2014 - 01:28 PM
Check if it has a mini usb plug on it as they are the later versions and I think most of the ones with mini usb have bluetooth streaming too?
#56 JW1982
JW1982
  • 565 posts
  • Name: Wilco
  • Year: 2013
Posted 13 January 2014 - 04:49 PM
All modules with USB support do also have A2DP (bluetooth Audio).
Initially only modules (with USB support) with part number 8M5T-19C112-AM and later did support A2DP. The modules with part number 8M5T-19C112-AK did originally not support A2DP but after the Ford Audio Update these modules also support A2DP.
#57 GothicRebel
GothicRebel
  • 226 posts
  • Name: Andy
  • Year: 2009
Posted 13 January 2014 - 05:06 PM
Nice one gents.
Again Thank you for all your help.
Wish I had the cable but you can't have everything.
Thanks Gents. Will update my build thread when the cable arrives thurs.
#58 GothicRebel
GothicRebel
  • 226 posts
  • Name: Andy
  • Year: 2009
Posted 21 January 2014 - 11:57 AM
Had a thought gents. After getting the wrong retro fit cable for the Bluetooth VC USB module I noticed that the cable has the mic connector. But it wasn't long enough to reach all the way up to my mic. Now when the newer retrofit cable arrives I guess the mic cable also won't be long enough. So I traced the current cable I have from my interior light.ImageUploadedByFord OC1390304607.549913.jpg
With mic attached.
ImageUploadedByFord OC1390304654.868830.jpg down my left brace to this socket.
When the new retrofit cable arrives. How do I connect it up?
9. Wires go into this grey connector but only 3 come out.
ImageUploadedByFord OC1390304816.089648.jpg ImageUploadedByFord OC1390304829.217896.jpg
#59 JW1982
JW1982
  • 565 posts
  • Name: Wilco
  • Year: 2013
Posted 21 January 2014 - 04:44 PM
The retrofit kit uses a different type of microphone which is mounted on the A-pillar cover. This is because not all Focus MK2/MK2.5 models have the large interior light frame with mounting hole for the microphone and the retrofit kit must be universal for all Focus models.
If you want to use the microphone in the interior light frame you have to extend the microphone wiring.
#60 GothicRebel
GothicRebel
  • 226 posts
  • Name: Andy
  • Year: 2009
Posted 21 January 2014 - 04:57 PM
Fantastic that answered that.
I guess I'd have to splice cables together. Does it matter which cable is connected to which other?
Not what you're looking for?
