Rear Drums To Disks Conversion. Mk2 1.6Petrol
brakes drums disks petrol 1.6 conversion
18 replies to this topic
#16 mrmetallica
mrmetallica
  • Budding Enthusiast
  • 331 posts
  • Name: john
  • Ford Model: focus titanium 1.6
  • Year: 2009
Posted 17 January 2014 - 01:09 PM
here you go very good guide i was sent by jw1982
Attached File  Drum brake to Disc brake conversion.pdf   2.3MB   287 downloads
Have something to contribute?
#17 Cragrat
Cragrat
  • 59 posts
  • Name: David
  • Ford Model: Focus
  • Year: 2009
Posted 20 March 2014 - 02:52 PM
I am considering carrying out this mod in the future on my 59 plate MK2.5, I did it on my Facelift Mk 1. What a difference it made especially with a heavy loaded car.
I do have a question about the hoses. I will be changing the brake hose set before I do the Mod and I see you changed them as part of the mod. Are the hoses different between the Drum and Disc? I don't want to get ones for the drums then in a few months time change the rear ones again. If it's just a matter of length then I would get the longer ones as these would fit both or is a more fundimental difference such as the fitting at the caliper end?
Thanks.
#18 JW1982
JW1982
  • True Ford Enthusiast
  • 695 posts
  • Name: Wilco
  • Ford Model: Focus MK3 Champions Edition
  • Year: 2013
Posted 20 March 2014 - 04:48 PM
Based on technical drawings of ATE there are a few differences between the rear brake hoses for disc or drum brakes.
* Lenght. The brake hoses for disc brakes are a bit longer.
* Fitting at the caliper end. The thread is the same (M10 x 1) but the threaded end of drum brake hoses is much longer than the threaded end of disc brake hoses.
* Position of the vulcanised rubber protection sleeve and mounting grommet.
Based on the technical drawings I suppose the brake hoses for disc brakes will probably not fit on drum brakes.
#19 Cragrat
Cragrat
  • 59 posts
  • Name: David
  • Ford Model: Focus
  • Year: 2009
Posted 20 March 2014 - 09:07 PM
OK thanks for that info. I may just change the front for now and change the rear at the same time as I do the mod. I will be going for braided steel hoses when I do.
Not what you're looking for?
Also tagged with one or more of these keywords: brakes, drums, disks, petrol, 1.6, conversion
