Mk2.5 Fog Wiring
focus fog
36 replies to this topic
#16 Realiks
Realiks
    Member
  • Members via FB
  • PipPip
  • 10 posts
  • Name: Ruben
  • Ford Model: Focus
Posted 21 February 2014 - 07:50 PM
The connector in the picture has a protective plastic cover. Just push the clip on the side and it should just slide of. Today I've also fitted fog lights on my focus mk2.5. Same wiring as shown in your picture. I've connected everything but they are not working :(
Did you order the kit from a ford dealer? I think mine have bulbs but if not that would explain why they don't work :). Did they work for you first try? Mine are branded "Valeo"
Did you already fit them? Do they work?
Have something to contribute?
#17 ClarkeLad
ClarkeLad
  • Budding Enthusiast
  • 62 posts
  • Name: Dylan
  • Ford Model: Ford Focus 1.6 TDci
Posted 21 February 2014 - 08:00 PM
Yes ive got it from a ford dealer, didnt come with bulbs, I ordered the bulbs today so will let you know. Did you connect the new switch?
Sent from my GT-I9505 using Ford OC mobile app
#18 Realiks
Realiks
    Member
  • Members via FB
  • PipPip
  • 10 posts
  • Name: Ruben
  • Ford Model: Focus
Posted 21 February 2014 - 08:07 PM
Yes, I've connected the new switch and the LED on my dashboard is showing, so I think everything is OK there.
I will check the bulbs tomorrow, maybe they broke during transport.. Will post an update here when I find out the problem.
#19 ClarkeLad
ClarkeLad
  • 62 posts
  • Name: Dylan
Posted 21 February 2014 - 08:13 PM
Did you dissconect the battery earth when fitting?
#20 Realiks
Realiks
    Member
  • Members via FB
  • PipPip
  • 10 posts
  • Name: Ruben
  • Ford Model: Focus
Posted 21 February 2014 - 08:20 PM
Yes I did. I've also checked the fuse which seems fine. The rear fog light does work.
#21 ClarkeLad
ClarkeLad
  • 62 posts
  • Name: Dylan
Posted 21 February 2014 - 08:28 PM
That was my next question, the fuse. Unless there is a bodywork computer which needs programed?
#22 Realiks
Realiks
    Member
  • Members via FB
  • PipPip
  • 10 posts
  • Name: Ruben
  • Ford Model: Focus
Posted 21 February 2014 - 08:36 PM
According to the ford dealer it's plug and play. I hope I'm not missing any wiring, the connectors did fit perfectly. I also purchased the wiring loom because I was misled by the plastic covers on the fog light connectors. I tough they were sensors until I compared them. :)
#23 ClarkeLad
ClarkeLad
  • 62 posts
  • Name: Dylan
Posted 21 February 2014 - 08:45 PM
Well its a good job you mentioned that tje wires had covers as I was going to buy the loom on monday I will probably be fitting them next weekend. How did you remove the battery earth?
#24 Realiks
Realiks
    Member
  • Members via FB
  • PipPip
  • 10 posts
  • Name: Ruben
  • Ford Model: Focus
Posted 21 February 2014 - 08:57 PM
I was fitting the loom and wanted to connect the loom inside the interior when I found Pin 19 of the connector was already used. Then I realized => God Dammit! I've just wasted 2 hours of work and 50€... Removed the loom and used the connectors that were taped against the bumper. I just hope I get them to work.
The battery earth can be removed by removing the protective battery cover (just pull, no screws) and unbolt the negative side of the battery. Make sure that you write down your radio code!
#25 ClarkeLad
ClarkeLad
  • 62 posts
  • Name: Dylan
Posted 22 February 2014 - 09:06 PM
i slid the cover off the wire there now, there is a white connector underneath does it connect directly into the bulb?
#26 Realiks
Realiks
    Member
  • Members via FB
  • PipPip
  • 10 posts
  • Name: Ruben
  • Ford Model: Focus
Posted 22 February 2014 - 09:19 PM
Yes it does.
#27 ClarkeLad
ClarkeLad
  • 62 posts
  • Name: Dylan
Posted 22 February 2014 - 09:21 PM
H11?
#28 Stoney871
Stoney871
    Resident Peacekeeper
  • Super Mod
  • 18,077 posts
  • Name: Clive
  • Year: 2015
Posted 22 February 2014 - 09:23 PM
On a facelift MK2? Yes.
#29 Realiks
Realiks
    Member
  • Members via FB
  • PipPip
  • 10 posts
  • Name: Ruben
  • Ford Model: Focus
Posted 22 February 2014 - 09:27 PM
Jup h11
#30 ClarkeLad
ClarkeLad
  • 62 posts
  • Name: Dylan
Posted 22 February 2014 - 09:31 PM
cheers!
Not what you're looking for?
Also tagged with one or more of these keywords: focus, fog
