SamBerry
Slip-On Spacers For Mk2 Focus
5 posts in this topic
Has anyone put slip-on spacers to a Mk2 Focus before? Think i'm Going to need some to miss the suspension with the Tyres on the wider wheels. Does anyone know what the maximum thickness of slip-ons i could use whith out having to change the bolts to longer ones?
about 7mm i believe i went to. but rubbed as !Removed! over bumps, and i wasnt comfortable knowing the threads werent fully in the nut. x
Ah, fair enough. Seen plenty of posts saying you should get at least six full turns with heel nuts but you only get about five and a half with standard wheels...
I've probably got my old ones in the shed. If ya want them... PM me your address, paypal postage and ill send freely!
I've also got some ebaich hub spacers - cant remember if they 10mm or 15mm. Ill sell them for cheap if your interested? I got different offset alloys now that bring the wheels out perfectly, so these are not needed anymore.
x
Sam
depends on how wide your going. plus, i'd prefer to use hubcentric spacers as they are safer. if you need longer bolts then try this place:
http://www.taperpro.co.uk/2012/locks.htm
i got my lucking nut set (all 20 bolts) from.
