AdBlock Warning
tkamdal
Ticking/clicking Sound From Engine Compartment? Ford Focus 1,6 (2000) Petrol.
4 posts in this topic
Need some expert help to locate an error, hope someone can give me some good hints.
My ford has a new sound in the engine compartment.
Its best described as a ticking/clicking sound which seem to be in more or less in sync with the "speed of the engine". It's quite loud and distinct.
I dont think its from the engine it self but likely in connection with the drivebelt. Not sure though.
It looks like I have a small wooble on the belt tensioner for the drive belt. is it likely that this is the cause, and in that case how easy/hard is it to fix DIY?
Any other obvious things i want to check out?
I might also add that it's drinking a descent amount of motoroil.(mileage:100 000)
Im afraid it might be something critical. Hopefully it's something I can fix myself.
Greatful for all tips and hints!
i tried to attach a sound file. Hope it's working.
ford.wav
Are spark plugs all okay?
Also check for oil leak as running the engine without or low could !Removed! ya motor.
The same day as i was planning to drive my car to the workshop the sound disappeared.
I do have an issue with the oil thou. It seems to be burning oil and i constantly have to pay attention to this. (ca. 1liter pr. 1000Km)
Always park in the same spot and can't see any signs of a propper leak.
The spark plugs are relatively new. Prob about 5000km. Something funky is going on thou.
When the engine is running on a low "speed" and i push the throttle hard the engine stalls/jumps a couple of times.
Last time I changed the spark plugs this problem went away. But it came back just after 2000KM on new spark plugs.
Anyone?
Thanks for any good advice!
