Hi, I have a 1997 Mk4 1.3 Ford fiesta.
I have a problem where sometimes the airbag light flashes. There is no pattern when this happens. I was told it could be the sensor in the seat?
Has anyone had this problem or know of a resolution.
Thanks,
Dan
Airbag light flashing occasionally.
Started by Dan Lewis, Mar 05 2008 03:54 PM
6 replies to this topic
#1
Posted 05 March 2008 - 03:54 PM
#2
Posted 05 March 2008 - 10:20 PM
To be honest I think you should seek professional advice on that. If there is a fault with the airbag and it deployed whilst driving could be dangerous.
#3
Posted 06 March 2008 - 12:48 PM
I just checked, and it is four flashes. Which is to do with the seatbeat?
#4
Posted 06 March 2008 - 09:23 PM
perhaps the connection under the seat?
When in the car with the seatbelt on try and lift yourself off the seat and see if the sensor creates a warning.
also, do you have any large shopping bags on the passenger seat? This can make the car thing there is a passenger in the car
Thats if it is the seatbelt warning
#5
Posted 31 March 2008 - 03:11 PM
I was reading on the internet, that you have to unplug the yellow cable under the seat, as this is suppose to work?
#6
Posted 31 March 2008 - 08:00 PM
that will probably disable the airbag for the passenger.
#7
Posted 30 April 2008 - 02:01 PM
i had a similar problem on an escort i had a few years back . . .
they apparently have a airbag sensor behind the steering wheel which is
held in place by a plastic bracket . . . the idea is that if you crash the plastic snaps and
the airbag deploys . . . i believe the sensor on mine had shorted out so it thought the airbag
had been used . . . . .
