naffygetter Posted January 19, 2014 Share Posted January 19, 2014 I have a UK 59 plate (2010 model) Fiesta RHD econetic diesel. Recently the heater fan has stopped working on switch positions 1-3, which I have diagnosed as a failed heater motor resistor. I have got a new resistor but now need to find where it is to do the swap. I thought it was behind the glove box- as shown/discussed in various web posts. However I can't see it. Can anyone give me a detailed description (or even a picture) of where it is? Thanks in advance for the help. Quote Link to comment Share on other sites More sharing options...
mgaking Posted January 19, 2014 Share Posted January 19, 2014 Don't know myself but have a look at this thread; http://www.fordownersclub.com/forums/topic/34919-2009-new-fiesta-heater-fan-fault/ Quote Link to comment Share on other sites More sharing options...
kieranL Posted January 19, 2014 Share Posted January 19, 2014 its at the foot well behind the glove box "I think." had same problem my dad looked yesterday. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted January 19, 2014 Share Posted January 19, 2014 Quote Link to comment Share on other sites More sharing options...
naffygetter Posted February 2, 2014 Author Share Posted February 2, 2014 I have now managed to find it and change it. I hope this will help any others that need to replace the resistor. First where is it? On my 59 plate, RHD Fiesta Mk7, it is on the passenger (near) side but hard to find. How to get at it? I had to remove the trim below the glove box. There are 2 black pull-out toggles that secure it and then it slides foward and can be removed. Next, I had to remove the trim that runs fore and aft, on the side of the centre console, just above the carpet. There is one black plastic plug (oddly has a phillips screw head but doesn't unscrew) that pulls out. If you can, pull the middle out and then it comes out easily. If you can't get the centre out it will pull out but care is needed. Then there are clips at the rear end of the panel (below and a bit back of the gear lever) taht also pull out. Take care to ease them out. Note that you do NOT need to take the glove box out. Once the panel is off, you can see the resistor. It is well forward, and hard to see (let alone to get at). This shows where it is and this shows it a bit better . This last one shows it in close up . Once you can see it, there are just the 2 torx screws to remove the resistor, unclip the connector block connect a new one and then put it back - replace the trim and it's all done. It sounds simple but is a struggle to get in there and be able to see what you are doing. I hope all this helps some other Fiesta owner. Given the history of faults on this component, it seems odd that Ford continue to use and to put it in such a difficult position. 1 Quote Link to comment Share on other sites More sharing options...
iNath Posted February 2, 2014 Share Posted February 2, 2014 Thanks for the details Richard, I have added this to our guides section here: http://www.fordownersclub.com/forums/tutorials/article/224-mk7-fiesta-heater-resistor-location-removal/ Quote Link to comment Share on other sites More sharing options...
stefinley58@gmail.com Posted March 19, 2017 Share Posted March 19, 2017 Mine is on the drivers side ,very awkward to gain access and reach ,advice welcome HELP! Quote Link to comment Share on other sites More sharing options...
