darrenshaggy Posted January 19, 2014 Share Posted January 19, 2014 hi all i had mot done when he was moting the car he pulled my rear arch lining back and found 2 holes in arches ive since been told that he wasnt allowed to pull back the linings is this the case also he told me to weld the holes and wasnt allowed to put seats back or carpet till hes inspected it but you can see it from the out side aswe cut rusty section out if he wasnt is there any documentation on it sorry for long essa Quote Link to comment Share on other sites More sharing options...
artscot79 Posted January 19, 2014 Share Posted January 19, 2014 if the tester has seen rust near a structural point on the car from underneath he can pull back the liner to take a closer look as it would be dangerous not to and yes he will need the seat and carpet left out so he can inspect the welding as it should be double welded ie underneath and inside and he will check the quality of the welding once thats inspected you need to seam seal the repair inside and underseal the underside Quote Link to comment Share on other sites More sharing options...
darrenshaggy Posted January 21, 2014 Author Share Posted January 21, 2014 thanks for the info Quote Link to comment Share on other sites More sharing options...
STEADS Posted January 21, 2014 Share Posted January 21, 2014 Wether he,s allowed to or not I,d personally have a safe car on the road don't care what they find on mine so long as I know they have done a proper inspection as that's what the mots there for . Quote Link to comment Share on other sites More sharing options...
FOCA Posted January 21, 2014 Share Posted January 21, 2014 Wether he,s allowed to or not I,d personally have a safe car on the road don't care what they find on mine so long as I know they have done a proper inspection as that's what the mots there for . There is a lot of "jobsworth" and "red tape" stuff that has nothing to do with safety involving MOTs,(and more coming as time goes on) ive seen death traps pass and good cars fail because of stupid things. To give you an example - you can't fit an ST225 twin exhaust to your car because you are not allowed to cut your spare wheel well Quote Link to comment Share on other sites More sharing options...
