Sign in to follow this
Followers 0
swatty
2004 modeo weird brake light problem
4 posts in this topic
hi all
well i have a 2004 mondeo and i noticed the other day that every time i engage the clutch the brake lights flash on then off
seems very strange as i have never come across this b4
any suggestions what this could be
Check the brake fluid level in the reservoir and top it up if it is low. In case the problem is cured then reappear few days later, check for any leaking of fluid near the gear box and brake pipes.
check that the brake light sensor at the pedal is tight.
Followers 0
