scoot600 Posted January 26, 2014 Share Posted January 26, 2014 I seem to be getting a lot of condensation on the inside of my rear window. I have checked the rubber seals around the edge and found that to be ok. I need to put the heated screen on quite alot Any clues? Quote Link to comment Share on other sites More sharing options...
STEADS Posted January 26, 2014 Share Posted January 26, 2014 Have you got anything wet in your boot I,e spare wheel well . Quote Link to comment Share on other sites More sharing options...
stevegtuk Posted January 26, 2014 Share Posted January 26, 2014 At this time of the year with the cold and wet weather, everyone will have condesation on their back windows. Quote Link to comment Share on other sites More sharing options...
Andy63 Posted January 27, 2014 Share Posted January 27, 2014 Put one of those condensation bags on the parcel shelf, I have just put one on dash board & one on parcel shelf, got them of amazon, they work great. Quote Link to comment Share on other sites More sharing options...
Jockstar Posted January 27, 2014 Share Posted January 27, 2014 My car is doing the exact same thing at the moment. Quote Link to comment Share on other sites More sharing options...
btmaldon Posted January 27, 2014 Share Posted January 27, 2014 Put the aircon on. That will dry the car out. Quote Link to comment Share on other sites More sharing options...
artscot79 Posted January 27, 2014 Share Posted January 27, 2014 its normal even using aircon the air may be dry but its warmer than the air outside so the warm air will be attracted to the glass which is cold once the temp inside matches the outside it dissapears you cant stop it thats just physics seal bags can help but its not due to leaks or seals just the weather Quote Link to comment Share on other sites More sharing options...
MattyD Posted January 29, 2014 Share Posted January 29, 2014 This is very common especially at this time of the year, my rear window always becomes condensated on the inside. Its a right pain but i usually give it a quick wipe on the inside to remove the bulk of the moisture and water droplets etc. This seems to help a little especially if your in and out in the car all day as i find it doesnt keep steaming up all the time. :) Quote Link to comment Share on other sites More sharing options...
artscot79 Posted January 29, 2014 Share Posted January 29, 2014 misting yes never had water droplets that indicates a leak Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted January 29, 2014 Share Posted January 29, 2014 Every time you open the hatch you find a little water drips into the boot. Ford do a proper clip on channel for the sides of the hatch which funnels the water away from the edges. A lad on a Forum I used to be on got some but as the site is now off I can't get the Finis numbers for them. I used some black beading on mine and it seems to help a bit- Quote Link to comment Share on other sites More sharing options...
artscot79 Posted January 29, 2014 Share Posted January 29, 2014 stoney mate the beading to work needs to have a gap inside and run from under the spoiler all the way down to the drain channel on the boot the water goes up the inside of the ford part and is then put into the drain above the boot Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted February 10, 2014 Share Posted February 10, 2014 For anyone that may be interested, I've managed to find the details of the official Ford hatch seals which work like a gutter when the boot is opened. hatch goes up - water runs under the seals and is chanelled in the correct direction to run off without pouring into the boot. Will fit MK2 and Mk2.5 Focus. Quote Link to comment Share on other sites More sharing options...
artscot79 Posted February 10, 2014 Share Posted February 10, 2014 water still goes in the boot ive got the ford ones and they either block up or they still aloow water to drip in the boot stupid design as usual Quote Link to comment Share on other sites More sharing options...
