Mondo2014 Posted January 30, 2014 Share Posted January 30, 2014 Hi all,i just bought my ford mondeo last week had no problems with the car until now,i drove the car down to shop on wednesday morning came back parked up abd went back into house,about an hour later went back out to car and tried to start and nothing! The ignition comes on as usual glow plug lamp lights up for a couple of seconds,the rev counter and speedo max out then go back to nil which it doesn't usually do,try to start and you get a click noise wich i suspect is the starter motor engaging,any thoughts on what this could be.My initial thought was a bad earth on starter or starter motor is goosed,was just looking for some thought before i start to have a look at it thanks Quote Link to comment Share on other sites More sharing options...
mick85 Posted January 31, 2014 Share Posted January 31, 2014 Right if u get it going on push start provided it's not automatic u will rule that out Quote Link to comment Share on other sites More sharing options...
Mondo2014 Posted January 31, 2014 Author Share Posted January 31, 2014 Ok will try push start today if it goes the could be a bad earth or starter motor? Is there a relay or fuse for starter motor? Quote Link to comment Share on other sites More sharing options...
matto2494 Posted February 2, 2014 Share Posted February 2, 2014 Sounds strange. If you get in and the rev counters max out an drop back sounds like a bad earth on the battery maybe. Quote Link to comment Share on other sites More sharing options...
Mondo2014 Posted February 2, 2014 Author Share Posted February 2, 2014 I was out at it today and tried to start it,i turned fans off and radio off,then the engine turned over slightly so it comfirms bad battery going to replace battery! But just as i go to do that can't open bonnet! So going to have to drill the barrel then open with a srewdriver the replace barrel and key! Quote Link to comment Share on other sites More sharing options...
matto2494 Posted February 2, 2014 Share Posted February 2, 2014 Mine gets stuck all the time. My advise would be to wd40 the barrel then get the key in an wiggle. I thought my key was going to snap when I turned it the other day. After that the wd40 came out now it's fine. Give it a try first Quote Link to comment Share on other sites More sharing options...
