jimjames2uk Posted January 30, 2014 Share Posted January 30, 2014 have a problem with my ford sport ka and wondered if anyone can shed any light on it . have had the temp warning light flash a few times then recently the radiator fan was running all the time but theres plenty of water in ka so thought id change the thermostat and temp sensor just in case there was a problem with them beld the system through went for run in ka all seemed well then fan cut in again so stopped ka to have a look when restarted the engine warning like came on i connected up to reader and fault code was p0117 which is engine coolant temp low imput but again theres plenty water in it and the header tank read a temprature reading of 70deg celsius hardly over the top there was very little pressure in header tank when removing cap and if you squeeze bottom hose the level in tank increases Quote Link to comment Share on other sites More sharing options...
delboy Posted January 31, 2014 Share Posted January 31, 2014 does the fan run pretty much all the time as it maybe the fan relay, thats what i had happen on my ford galaxy so maybe woth a look. they are not much to replace as they dry out inside & the contacts break on them the relay mabe k35 on diagram now sure though https://www.google.co.uk/search?client=firefox-a&hs=4mT&rls=org.mozilla:en-US:official&tbm=isch&imgil=t4Qu9mo7zss8gM%253A%253Bhttps%253A%252F%252Fencrypted-tbn2.gstatic.com%252Fimages%253Fq%253Dtbn%253AANd9GcTfXL__OO1WzhSTYTsAba8SQybdrG2Ph6kZOZ-PdanpesBfIBrQ%253B800%253B600%253B9RH-WAOWqG-hsM%253Bhttp%25253A%25252F%25252Fwww.mwstewart.co.uk%25252Fcars%25252Fmk3enduratdi%25252F&source=iu&usg=__S02NxxWOH1r4JMO0IjHJaRTQfOI%3D&sa=X&ei=50DrUrSOMqar7Abur4HYDQ&ved=0CGUQ9QEwCA&biw=1680&bih=878&q=where%20is%20the%20ford%20ka%20engine%20fan%20relay#facrc=_&imgdii=_&imgrc=pV78OngxCwIrVM%253A%3Bv-_spKNVDu7_8M%3Bhttp%253A%252F%252Fwww.fordwiki.co.uk%252Fimages%252F0%252F06%252FEngine_bay_relays.jpg%3Bhttp%253A%252F%252Fwww.fordwiki.co.uk%252Findex.php%253Ftitle%253DFuse_%252526_Relay_Information%3B730%3B775 Quote Link to comment Share on other sites More sharing options...
