Zetec Se Engine Swap
21 replies to this topic
#16 carl1991
carl1991
    Member
  • Budding Enthusiast
  • PipPip
  • 12 posts
  • Name: carl
  • Ford Model: Focus 1.6 Zetec
  • Year: 2002
Posted 01 February 2014 - 09:24 PM
Yes all connected correctly, thus presuming cylinder 1 is timing belt end?
Well and truly stumped.
Have something to contribute?
#17 carl1991
carl1991
    Member
  • PipPip
  • 12 posts
  • Name: carl
  • Year: 2002
Posted 01 February 2014 - 09:36 PM
Getting worried now about flywheel. I have just read online about cars not starting after flywheel replacement....
 Flywheel was replaced as for some reason my clutch would not go on the other engine, there were no dowels for the clutch to sit on, so I just swapped them, does the flywheel have to be put back in a certain position?
#18 FOCA
FOCA
    Feet on the table
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 2,867 posts
  • Name: FOCA
  • Ford Model: Mondeo Mk3 Sleeper 194 flb.p.t.
  • Year: Non
Posted 01 February 2014 - 10:11 PM
The ignition timing may be taken off the fliwheel, thats how the ECU knows the crank position  if its in the wrong position the spark may happen at completely the wrong time
#19 carl1991
carl1991
    Member
  • PipPip
  • 12 posts
  • Name: carl
  • Year: 2002
Posted 02 February 2014 - 08:27 AM
Haynes never stated anything. Hope i dont hace to remove it!
#20 FOCA
FOCA
    Feet on the table
  • PipPipPipPipPip
  • 2,867 posts
  • Name: FOCA
  • Year: Non
Posted 04 February 2014 - 06:32 AM
Haynes assumes the replacement parts are identical to (and compatible with) the original ones
Problem is, you don't know if this is the reason the engine does not start
#21 carl1991
carl1991
    Member
  • PipPip
  • 12 posts
  • Name: carl
  • Year: 2002
Posted 09 February 2014 - 04:30 PM
This has now baffled 2 mechanics?!
 Timing is correct, fuel ok, no fault codes new crank sensor as one mechanic said it had intermittent spark, how many times should each plug spark when taken out and observed when cranking? i.e., my plugs fire sort of  /...../...../...../ should it be more of a ./././././././.... - I imagine that doesn't make much sense but imagine the forward slash to be spark, full stop to be pause, basically should they be firing a lot quicker than they are?
#22 Nathan_M
Nathan_M
  • Members via Twitter
  • 837 posts
  • Name: Nathan
  • Ford Model: Fiesta Flame Mk6
  • Year: 2004
Posted 05 March 2014 - 07:31 AM
Are the leads in a decent condition aswell as the coil pack as that would effect the spark quality and frequency?
Sent from my GT-N5110 using Ford OC mobile app
Not what you're looking for?
