Ben123 Posted February 2, 2014 Share Posted February 2, 2014 Hi just ask a question about repair of cluster I read all the threads about it I have the usual problems I think with solder joints on back of 32pin plug so have tried to heat up solder joints with standard soldering iron but the don't seen to heat up pins enuf iron is very hot as melts normal solder I. Don't see it heating up joints do I need a special high heat soldering iron maybe people who have repaired one can tell me thanks Quote Link to comment Share on other sites More sharing options...
JW1982 Posted February 2, 2014 Share Posted February 2, 2014 I repaired a lot of Focus MK2/MK2.5 instrument clusters using a normal (cheap) soldering iron. In my opinion there is no need to use a special high temperature soldering iron. You have to make sure the tip of the soldering iron is clean to have a good heat transition between the soldering iron and the soldering connections. There may be a transparant coating against corrosion on the soldering connections which has to be removed before soldering. I have seen this before on some MK2/MK2.5 circuit boards. I Always remove the coating with a solvent or alcohol and a small brush before soldering. I never tried to resolder the connections without removing the coating Quote Link to comment Share on other sites More sharing options...
Ben123 Posted February 2, 2014 Author Share Posted February 2, 2014 Thanks what I was trying to do was just ltrying to melt its own solder but when I touch the top of it did not seem to be melting it even though the iron is very hot will give it another go thanks Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted February 6, 2014 Share Posted February 6, 2014 Also one tactic I learned with melting solder, is to make sure that you have a drop of new solder on the old solder joint. The new solder melts easier and bonds with the old solder allowing the solder bond to break and the solder to all become free. Quote Link to comment Share on other sites More sharing options...
Ben123 Posted February 6, 2014 Author Share Posted February 6, 2014 Hi yes I have it all back now all seems ok so far so hope it lasts thanks Quote Link to comment Share on other sites More sharing options...
