shazza14
Ford Fusion Cuts Out
11 posts in this topic
hi all
i have an '02 fusion 2 1.4 16v
it starts and drives fine
but on occasions, it will just cut out on decceleration
as i'm slowing down coming up to a junction for instance, the engine will just die
it will re-start without problem by either bumping it while its still moving, or by the key
i've fitted new plugs, ht leads and coil seem ok
i've checked usual connectors ands hoses etc
but cant find anything amiss
i have an OBD reader, but that doesnt show any faults
it doesnt cut out all the time, or at any peticular moment
some days it wont do it at all, or on some journeys it may do it 1/2/3 times
can anyone help? i'm at a miss
many thanks for reading
When was the fuel filter last changed?
Sent from my GT-N5110 using Ford OC mobile app
only bought the car recently
have to say though, that when i bought it, it had just about NO fuel in it
have tried some red-ex in the tank, which seems to be helping a bit
do you think a fuel filter change might be advisable?
Well its 10 or 15 quid max so probably, either way you aren't losing anything.
ok will do it, thanks for your help
Changing the fuel filter certainly won't hurt, but am I right in assuming it dies when you press the clutch to change down gears?
If so, then the idle control valve could be the problem.
Yes it only happens when i change down gears, but not all the time. today its has not done it at all.
will also look at getting this changed too
many thanks
In these circs I'd be checking your crank sensor. When they fail they cause intermittent no start/cut out. :)
Hi, my Fusion is doing exactly the same thing. I have a bit of history though which may help. I had my cam belt changed but in the process of doing it the mechanics couldn't get the main bolt out, after a while and having to cut the bolt they were able to change the belt.
After that was done my engine would just cut out going round corners but as the previous poster said not frequently. I had sensors put on and the engine checked but nothing was found. So they decided to strip it back down to the cam belt and start again just to make sure nothing was damaged etc. Well this has made the issue considerably worse. Its going back in on Tuesday but we had to get a new code for the radio as the one that was with the manual did not work so we went to our local Ford dealership to get one, while there we asked one of the head mechanics if they had any idea. So he jumped in and took it for a spin ( (cut out on him and then he made it happen several times) and his diagnosis was that the cam timer is out.
Now this is probable for my case due to my issues starting after the cam belt was changed. I'll certainly mention to my mechanic about the crank sensor, idle control valve as well as the cam timing.
Fingers crossed you get your car sorted as i hope mine will be.
Mikey923 likes this
Sounds like air leak in engine manafold. .I ad problems with same n changed all filters. .plugs..ecu..throtle body. .sensors an still same so paid ford dealer to do few hrs on checking the wire at 60+vat an hr they came up with air leak..waiting now so fingers crossed
Thought I would post an update on my fusion cutting out every now and again. I've read an article stating that the fusion has inherited the problem from the fiesta which also cuts out at times at junctions etc. So this is a common fault and clearly one that Ford know about but obviously won't admit.
