Mondeo Mk4 Error Codes
Italiot
 Share
Hi all
I have had my fsuper connected today and have found two dtc error codes but i dont know what they are is there a code list anywhere or has anyone had and resolved these errors
codes
P11AAFINED DTC
p1100
all help will be gratfully apreciated thanks
post-49908-0-12966200-1392145007_thumb.p
Link to comment
Hi all
codes
P11AAFINED DTC
p1100
http://www.talkford.com/topic/211183-mondeo-20-mk4/ Hopes this helps
Link to comment
Thanks that answers the codes for me can anyone tell me where the map sensor and manifold pressure sensor is as I can't see online
But with the error codes will they auto clear or do they have to be cleared as this is my first time having to get this info from the car
Link to comment
Have u had any work done recently is performance down have u got a multimeter
Link to comment
The clutch and flywheel was replaced in December I do have meter I have had a issue with acceleration dropping in and put on the motorway about 75mph it performs well all other times
Link to comment
Here are some pics can anyone point out the maf and map sensors please I have an idea but not certain
post-49908-13922263424_thumb.jpgpost-49908-139222635494_thumb.jpgpost-49908-139222636829_thumb.jpg
Link to comment
MAF is the sensor between the air filter box and the air filter trunking, in your 3rd pic, you can see the sensor connector between battery and air filter....dont think you have a MAP on that engine
Link to comment
I'm not sure I'm just going by the p11aafined dtc code above identified via talk ford link on second post
Also euro car parts show map sensor against my reg
Link to comment
no listing for map, only maf.....
had no experience with this code, but wondering if the air flaps in the manifold are playing up...could trigger a maf/map code
sure somebody on here have more experience with this issue of air flaps/control arm
  • Like 1
Link to comment
i have just been looking through the haynes repair book have managed to identify the map sensor and also the maf sensors for the mk4 2.0 tdci have marked on picture red indicates map sensor and yellow indicates maf sensor this is the first time im pulling codes from the car so will the dtc need to be cleared after cleaning or will it clear on its own could you please advise thanks
post-49908-0-51651300-1392232523_thumb.j
post-49908-0-92484400-1392232543_thumb.j
Link to comment
that isnt actually a map sensor, but can understand the confusion as it does a similar task to a map...it measures air pressure but is linked to the turbo and/or the manifold air flaps
Link to comment
I know the books are not always right so would you say that would be the only sensor which can be classed as map there
Link to comment
would be the only one that would make any sense, but its not a true map sensor
Link to comment
I've stripped the two sensors off an cleaned them the car is going in for the fifth service beginning of March then will be on long run will then will find out if it has worked
Does anyone have a list of what parts ford should be replace in the services
Link to comment
Can this fsuper be trusted to be correct on mk4
Link to comment
I have looked on the internet and seen these error codes show up a lot and have cleaned the two sensors in question cleared it on formidable and as soon as the car is reved they come straight back codes again are
P11AAFINED DTC - PCM SECTION
P1100 MASS AIR FLOW SENSOR CIRCUIT INTERMITTENT
I can go and buy the sensors and replace them but want to be sure I won't be wasting money on parts not needed has anyone any info weather the errors can be got rid of or not
Link to comment
couple of voltage checks you can do.
turbo boost pressure sensor (one youve ringed in photo/map)
3 wire sensor...plug connected...engine idling
terminal 1 (blue and white) and 2 (green and blue)= 5volts
terminals 2 and 3 (yellow and green)= 2.3volts
engine idling, accelerate briefly
terminal 2 and 3 =2.9volts briefly
MAF
only have a supply test which is
terminal 3 (violet and grey) and earth point = battery voltage
Link to comment
  • 5 years later...
Hi i have some error on my a/c it's some one to explabe me what its that
77F0
6f09
Link to comment
77F0
6f09
You really need to start your own thread, your question has nothing to do with the issue the Op for this thread is having.
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
