paulaldo
How To Fit Door Sill
5 posts in this topic
Hi all
I have bought a set of door sill and they turned up today
http://www.ebay.co.uk/itm/Ford-Fiesta-Zetec-S-Silver-Stainless-Steel-Kick-Plate-Door-Sill-Protectors-K01X-/261175712262
And I was wondering if I have to remove the door seal to fit them or does it just slide underneath it
Hi.
All you need to do is peel off the sticky protectors behind the sill plate and stick straight onto the sill.
Hope this helps.
Thanks Adam for the quick reply but after you take the tap off do they slide them under door seal or do you remove the door seal fitted them and put the door seal back after you have fitted them
They just stick straight on, nothing needs to be removed
Just be sure that the sills are clean first.
Ensure that you mark exactly where the plates are going to line up as once stuck down they won't move again - Ever.
