Mk3 2.0 Tdci Starting Problems
52 replies to this topic
#16 Italiot
Italiot
  • Budding Enthusiast
  • 275 posts
  • Name: Aaron
  • Ford Model: Mondeo titanium x 2.0 tdci 140bhp
  • Year: 2009
Posted 13 February 2014 - 07:36 PM
It could be the imobiliser try see if this fault code list helps any
http://www.fordwiki.co.uk/index.php?title=PATS_Immobiliser_Fault_Codes
Have something to contribute?
#17 owensy
owensy
  • 35 posts
  • Name: Paul
  • Year: 2004
Posted 13 February 2014 - 08:30 PM
Right I've been out and the battery is showing 12.45 volts so that appears to be ok. I have tried to start the car using the other key but now I have noticed that on the dash the car display for the doors and the side light display are the only ones lit. Not even the mileometer is showing anything! I dont know if this maybe because I tried to jump the car this morning? The plot is thickening!
#18 Italiot
Italiot
  • 275 posts
  • Name: Aaron
  • Year: 2009
Posted 13 February 2014 - 08:31 PM
Where did you connect you jump cables
#19 owensy
owensy
  • 35 posts
  • Name: Paul
  • Year: 2004
Posted 13 February 2014 - 08:38 PM
on to the battery connections
#20 Italiot
Italiot
  • 275 posts
  • Name: Aaron
  • Year: 2009
Posted 13 February 2014 - 08:44 PM
Both connections was the battery cover not covering one of the terminals
As should be positive connected to the battery and clip the negative on to metal on the engines
#21 owensy
owensy
  • 35 posts
  • Name: Paul
  • Year: 2004
Posted 13 February 2014 - 08:46 PM
nope. There is only a large plastic cover and I connected positve to positve and negative to negative direct from one battery terminal to the other.
Your worrying me now :wacko:
#22 Italiot
Italiot
  • 275 posts
  • Name: Aaron
  • Year: 2009
Posted 13 February 2014 - 08:53 PM
The negative terminal should be blocked off on any within last 15 years
When you measure the battery voltage is the key switch to battery position or turned off or someone trying to start while voltage being measured as I would measure while someone try to start it to show true reading while power is being introduced
#23 owensy
owensy
  • 35 posts
  • Name: Paul
  • Year: 2004
Posted 13 February 2014 - 08:55 PM
It does not appear to be blanked off.  I tested the voltage with no keys in the ignition just as it was sat in the car
#24 Italiot
Italiot
  • 275 posts
  • Name: Aaron
  • Year: 2009
Posted 13 February 2014 - 08:58 PM
Try checking voltage with someone trying to start it
Also have you looked to see if these pats codes are showing
Link again
#25 Italiot
Italiot
  • 275 posts
  • Name: Aaron
  • Year: 2009
Posted 13 February 2014 - 09:00 PM
If you have a phone which can record a video of it record and post it
#26 BigD
BigD
  • True Ford Enthusiast
  • 631 posts
  • Name: -
  • Ford Model: -
  • Year: Non
Posted 13 February 2014 - 09:01 PM
You don't do it like that.
Positive to positive first, then connect the negative of the good battery to somewhere metal on the dead car for a good earth.  Nothing should be connected to the negative terminal of the dead battery.
#27 owensy
owensy
  • 35 posts
  • Name: Paul
  • Year: 2004
Sure I think Ill have to wait for it to get light though! May not be until Saturday unless I get time in the morning
#28 owensy
owensy
  • 35 posts
  • Name: Paul
  • Year: 2004
Posted 13 February 2014 - 09:52 PM
To be fair the battery was not dead but I will bare this in mind. I hope this hasn't effected the electrics
#29 owensy
owensy
  • 35 posts
  • Name: Paul
  • Year: 2004
Posted 15 February 2014 - 04:41 PM
OK I think it's the starter. Been out and it was still just clicking. Got someone to turn the key and there were sparks from where the but holds the cable onto the motor and it was sparking and smoking (although I had sprayed wd 40 on) and I hit it with a mallet and it turned over but very slowly but with more smoke coming off the connector.
#30 Italiot
Italiot
  • 275 posts
  • Name: Aaron
  • Year: 2009
Posted 15 February 2014 - 04:43 PM
That is a clarkson move at least you have found the problem
Not what you're looking for?
