big g1985
Strange Electrical Fault
After my wife drove through a big puddle we e had a strange electrical fault when u lock the car (54 plate 1.6 tdc)
Basically when you lock the car the wipers will operate a small amount and the heater control lights illuminate then go out.
I've check the fuse box in the engine bay and I've noticed here is a loose live cable at the top of the box
Can't see where it should attach.
I've moved it out of he way I case it was shorting on something but I still have the same fault
Any help will be appreciated
Turns out it was moisture in the cabin fuse box corroding the contacts supposibly a common fault
