Sharifgh
Mk2 Rear Parking Aid Control/sensor Unit
6 posts in this topic
I have a mk2 07 plate focus zetec with factory fitted reverse sensors. When I engage reverse the reverse light comes on and hear a beep once, but the sensors do not detect any obstruction. I suspect the sensor unit had failed. There are some on fleabag but I want to locate the one in the car first.
I thought it was in the boot on the RHS under the fabric fitting above the wheel arch. I see wires coming through a rubber grommet in the floor of the boot bit cannot see the control unit when I follow the wires
Please can you help to find it?
Sharif
The module is usually in the left corner of the boot so that the module is closer to the reverse light loom.
Thank you.
Also I cannot download your Sony Dab retrofit guide. Can you reup?
Still can't get it.
Can you email it to me at sharifgh at sky.com?
