WAZ91 Posted February 18, 2014 Share Posted February 18, 2014 Hi All, Just a quick one. i need to replace front brake discs and have been asked which size i need? the choice was 278mm or 300mm? its a good £20 differance between them too! the car is bog standard MK2.5 Zetec with 16" rims, I would just pop a wheel off and check but when i get home from work its dark! Thanks for the help Quote Link to comment Share on other sites More sharing options...
blue flash Posted February 18, 2014 Share Posted February 18, 2014 I have 300mm on my ghia 2005. Quote Link to comment Share on other sites More sharing options...
JW1982 Posted February 18, 2014 Share Posted February 18, 2014 The front disc diameter depends on the engine type. On the 1.4, 1.6 Duratec, 1.8 Duratec HE Petrol engines and 1.6 TDCI Diesel engines the front disc diameter is 278 mm. On the 2.0 Duratec HE Petrol engines and 1.8 and 2.0 TDCI Diesel engines the dront disc diameter is 300 mm. 1 Quote Link to comment Share on other sites More sharing options...
blue flash Posted February 18, 2014 Share Posted February 18, 2014 Yes,1.8 diesel I have. Quote Link to comment Share on other sites More sharing options...
stef123 Posted February 18, 2014 Share Posted February 18, 2014 As above, 300mm on the 1.8tdci Quote Link to comment Share on other sites More sharing options...
WAZ91 Posted February 18, 2014 Author Share Posted February 18, 2014 Trust it to be the more expensive size haha. Haha thanks guys :-) Quote Link to comment Share on other sites More sharing options...
WAZ91 Posted October 27, 2014 Author Share Posted October 27, 2014 Just to bring this up again :P what size should the rears be? 265mm 280mm guessing the 280? Quote Link to comment Share on other sites More sharing options...
JW1982 Posted October 27, 2014 Share Posted October 27, 2014 It depends on the size of the front brake discs. If the car has 278 mm front discs the rear discs are 265 mm. If the car has 300 mm front discs the rear discs are 280 mm. Installing the wrong size brake discs at the rear (in relation to the front disc size) will result in an incorrect brake distribution. The 1.8 TDCI should have 300 mm brake disc at the front and 280 mm brake discs at the rear but you should check the size before ordering brake discs 1 Quote Link to comment Share on other sites More sharing options...
WAZ91 Posted October 27, 2014 Author Share Posted October 27, 2014 I thought it would be the larger ones made sense with the fronts being 300mm, but just wanted to check :) Quote Link to comment Share on other sites More sharing options...
