Footwell Lights Mk3 ??
25 replies to this topic
#16 Stoney871
Stoney871
    Resident Peacekeeper
  • Super Mod
  • 16,024 posts
  • Name: Clive
  • Year: 2007
Posted 24 February 2014 - 02:58 AM
Same connectors as supplied with OEM illuminated gear knobs.
You could probably find matching connectors on ebay or just cut the plugs off the wires and solder/crimp self adhesive LED strips to the wires.
Have something to contribute?
#17 fours600
fours600
    Member
  • Budding Enthusiast
  • PipPip
  • 28 posts
  • Name: Paul
  • Ford Model: ford focus zetec mk3
  • Year: 2011
Posted 24 February 2014 - 01:25 PM
Well not only the gear knob the illuminated sills as well you can buy the wiring for £15.00 have a look at this post ...You need to purchase two connection cables - ford part num BM5J-14F009 A.
 http://www.talkford....nd-sill-plates/
#18 fours600
fours600
    Member
  • PipPip
  • 28 posts
  • Name: Paul
  • Year: 2011
Posted 25 February 2014 - 12:49 PM
hi everyone just pop up to my loacal ford dealers and orederd the scufff plate wires Part Number:   1741802   (QTY2) for £15.00
will fit them when they arrive will keep you guys posted
#19 fours600
fours600
    Member
  • PipPip
  • 28 posts
  • Name: Paul
  • Year: 2011
Posted 28 February 2014 - 07:10 PM
Well guys got my loom from ford and did a temporary attachment with the blue lights.got in the car and plugged the loom into the plug under the drivers dash. and Hey Presto it worked and went off with the courtesy lights icon_smile_hihi.gif the loom part number for the loom is BM5J=14F009 x 2 cost £15.00 heres the led strips off ebayhttp://www.ebay.co.u....84.m1497.l2649
and below pic of the lights working so i will get back to you all when i fit them in the car[
attachment=12844:IMG_20140228_161006.jpg]IMG_20140228_161236.jpg IMG_20140224_133624.jpg
#20 sparksy32
sparksy32
  • 66 posts
  • Name: mark
  • Ford Model: zetec s
  • Year: 2013
Posted 17 March 2014 - 02:42 PM
Have you got a better pic of the 3 pin connector as it looks like a 3 pin fan connector you get in pcs. In which case you can buy phobya high intensity led strips that will plug straight in no modding.
Mark
#21 fours600
fours600
    Member
  • PipPip
  • 28 posts
  • Name: Paul
  • Year: 2011
Posted 18 March 2014 - 12:31 PM
Hi mark had a look at the phobya high intensity led strips will not fit .the female socket are for four wires not three. And the socket is the wrong shape here's a pic of the footwell socket it is L shaped
I did try to find a socket the same but only way you will find one is from ford nowhere else
#22 sparksy32
sparksy32
  • 66 posts
  • Name: mark
  • Year: 2013
Posted 18 March 2014 - 03:44 PM
Just had a look at my ones in my pc and the leds come with a 4 pin inline molex and a 3 pin fan connector so you can run it via the motherboard or power supply. As for the l shape by the looks of it you would just need to file off the runners on the female side and job done.
The little runners on the bottom can be filed off and use some electrical tape to secure the 2 together
Just a thought
Mark
#23 sparksy32
sparksy32
  • 66 posts
  • Name: mark
  • Year: 2013
Posted 18 March 2014 - 05:45 PM
Another question. Does ambient lighting come on with the side/head lights?
Mark
#24 fours600
fours600
    Member
  • PipPip
  • 28 posts
  • Name: Paul
  • Year: 2011
Posted 18 March 2014 - 07:46 PM
Hi mark right the ambiant lights work same as the dome light. come on when they do and turn off when they do..but at night or when it is dark in a garage or tunnel ect. they turn on there must be a light sensors so they are not on all the time during daylight but they are on at night like the dash lights. Hope that explain it for you .
#25 jimrex
jimrex
  • 576 posts
  • Name: James
  • Ford Model: 2011 Mk3 Focus, 2009 Mk7 Fiesta
  • Year: 2011
Posted 18 March 2014 - 07:52 PM
As fours600 has eluded to, the ambient lights do come on with a light sensor, which is located at the base of the windscreen on top of the dash... If you cover it over with something dark they'll light up :)
Sent from my GT-I9505 using Ford OC mobile app
#26 hotstuff39
hotstuff39
    Newbie
  • Members via FB
  • Pip
  • 2 posts
  • Name: peter
  • Ford Model: focus zetec
  • Year: 2014
Posted 31 July 2014 - 03:47 PM
Ye found a bulb holder on the n/ s but it looks a bit small dont know what bulb will fit. Hotstuff39,
Not what you're looking for?
