Mark1eboy Posted February 19, 2014 Share Posted February 19, 2014 Hi all does anyone know how expensive it is to repair the head as I've done an initial test and it has suggested my gasket is leaking a little. Quote Link to comment Share on other sites More sharing options...
andy86 Posted February 19, 2014 Share Posted February 19, 2014 If it's in the early stages I'd get some steelseal really good stuff worked in every car I've had even when it was missing on 2 cyclinder it's about 34 quid but I think it's cheaper on eBay just make sure you get the steelseal it's a green liquid not the other cheaper stuff it never works all you do is put it in the water and run it Quote Link to comment Share on other sites More sharing options...
Mark1eboy Posted February 19, 2014 Author Share Posted February 19, 2014 I've tested it as I'm loosing a little water and I put a tester with a chemical in the expansion tank and the chemical want from blue to green. I was told it's the gasses that react with the chemical. I'm hoping it's a slight leak but can't really tell other than adding a little water every 3 days or do back in the expansion tank. Quote Link to comment Share on other sites More sharing options...
andy86 Posted February 19, 2014 Share Posted February 19, 2014 I'd put that in works for me everytime and I work at a garage doing a lot of traders cars who don't want to spend 350 gerrin the head done Quote Link to comment Share on other sites More sharing options...
Mark1eboy Posted February 19, 2014 Author Share Posted February 19, 2014 So is it a liquid that finds holes then? Quote Link to comment Share on other sites More sharing options...
andy86 Posted February 19, 2014 Share Posted February 19, 2014 Yep read up about it here's the link http://www.steelseal.co.uk if you search it on eBay it's about 25 quid Quote Link to comment Share on other sites More sharing options...
btmaldon Posted February 20, 2014 Share Posted February 20, 2014 http://www.ebay.co.uk/itm/Steel-Seal-Head-Gasket-Engine-Block-Repair-Fix-Pour-In-Liquid-/291071360858?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item43c5347f5a Quote Link to comment Share on other sites More sharing options...
Mark1eboy Posted February 20, 2014 Author Share Posted February 20, 2014 Ok thx for your help. Quote Link to comment Share on other sites More sharing options...
mjt Posted February 20, 2014 Share Posted February 20, 2014 I'd put that in works for me everytime and I work at a garage doing a lot of traders cars who don't want to spend 350 gerrin the head done So - typical trader's bodge to try and keep it going until it's out of warranty? We'll know who to steer clear of then. Quote Link to comment Share on other sites More sharing options...
andy86 Posted February 20, 2014 Share Posted February 20, 2014 Traders always do it it's a cheap fix and last a very long time I tried it in my girlfriends Clio and it's still running 4 years later Quote Link to comment Share on other sites More sharing options...
