Lee Oyston Posted February 24, 2014 Share Posted February 24, 2014 Hi I have a ford fiesta zetec 1.4 blue edition 58 registration, I recently found out that taking off the air filter hose out it makes a loud noise which I want, However obviously it's on for a reason, is their any affects what's so ever on the car and also can anyone help me on what air filter to get as in the meantime with a budget of 50 pound. Thanks lee Quote Link to comment Share on other sites More sharing options...
FOCA Posted February 25, 2014 Share Posted February 25, 2014 if the hose is between the filter/ engine, with the hose off it bypasses the filter so any dust/ dirt / stones/ debris that gets near can be drawn into the engine, causing wear etc, over the long term it can wear out the rings/ bores, "tottaling" the engine if warm air is being drawn you can loose power the air filter/ inlet may be a "tuned length" to increase low end or midrange torque, you may loose this advantage with the hose removed The engine may run lean with the hose removed, this can effect the emmisions and damage the catalytic converter Apart from that it should be ok Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted February 26, 2014 Share Posted February 26, 2014 lol, well put there Foca ;) To be honest, you wont get the noise you want from replacing the filter. I fyou want performance and a bit more noise, use K&N, otherwise, dont expect the noise to improve. If you want more noise, upgrade the exhaust :) Quote Link to comment Share on other sites More sharing options...
