vince_13 Posted February 28, 2014 Share Posted February 28, 2014 recently purchased an ST spoiler with the brake light missing, although searching for the upgrade kit including the wiring connector and pipe extender etc i cant find it anywhere, i was told that the ford CMAX has the same rear brake light, question is does the CMAX use the same wiring connector on the high level brake light as the MK2.5 focus? Quote Link to comment Share on other sites More sharing options...
Gabbo_21 Posted February 28, 2014 Share Posted February 28, 2014 I have washer and hose if you need one Sent from my iPad using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
vince_13 Posted February 28, 2014 Author Share Posted February 28, 2014 yes please m8 ill need them anyway thanks ill PM you Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted February 28, 2014 Share Posted February 28, 2014 The brake light from a C-max and Focus Zetec S both fit. You will need to source a plug with some wire to it as the lights use a different connector. Quote Link to comment Share on other sites More sharing options...
vince_13 Posted February 28, 2014 Author Share Posted February 28, 2014 Do they all use the same connector? Im off to scrappy tomorow and I doubt there will be an st there but more likely be a cmax so if that uses the same connector ill cut that Sent from my C6903 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted February 28, 2014 Share Posted February 28, 2014 All the same connector for that style brake light. Quote Link to comment Share on other sites More sharing options...
vince_13 Posted February 28, 2014 Author Share Posted February 28, 2014 Ok thanks hopefully I won't return empty handed tomorrowdidnt even leave my house, rang up a few scrapyards and they dont have any focus at all nor ford cmax Quote Link to comment Share on other sites More sharing options...
