big g1985
Water Leak Into Boot
7 posts in this topic
Got a water leak into the boot of my wife's 54 plate c max.
The garage sealed around the wiper as they thought I was coming in through there. Well it's still leaking.
I've had the trim out today and a hose pipe on the go.
It's not leaking around the light fitting but it's damp up around the top of the inner panel.
I can't see where it's coming in and there's nothing obvious.
I had one drip by the seat belt mount on a double skin but again I can't see where it's coming from
Any help will be greatful
Pic shows where it's dripping in by the double skin
post-51201-0-00492000-1393943784_thumb.j
Have you checked the rubber seal around the outside of the boot, I suspect water is leaking through from there?
Seal is fine I sat in the car whilst the wife sprayed it with the hose for 10min
Sounds like it might be the light cluster?
Sent from my MY SAGA C2 using Ford OC mobile app
Not light cluster either had it in and out and all dry around there
weird, those are the only two places I can think, unless of course water is seeping in through the roof rail. down the drain and leaking out into the boot from there?
Hi I'm having the same problem, did you manage to sort it? Thanks
