Phone function
cristian
Hi all,
I have a problem with my new Fiesta Phone function: when I press the M(mode) button in the left part of the steering wheel to answer a phone call, the call is rejected.
I read in the manual that the M button is used for: Accepting an incoming call:
Incoming calls can be accepted by
either:
• Pressing the ‘PHONE’ button on the audio unit.
• Pressing the ‘MODE’ button the
remote control
I've been trying to answer a call by pressing the M button on the steering wheel but it rejects the call....So what should I do? Maybe there is an option on the bord computer? Or not??
Thanks in advance!
Hi all,
either:
remote control
Thanks in advance!
Never used the 'M', i use the Answer one on the dash, far left as displayed on screen
I use the M on the wheel and works fine for me :S maybe best to take it in to the dealer for a check up.
Thanks. I guess I will go to the dealer
, maybe they can set this button, but it's very strange because I can finish a call by pressing the 'M'...
Probably the 'M' Button has been programmed to 'End' Or 'Reject' a call.
Yeah, it's been programmed to end a call, but also to accept a phone call....
I have the same problem with mine. When i press M it rejects the call. Pressing accept on the dashboard works fine though.
I can accept or end a call using the M button on the steering wheel. so nothing wrong here,
doesnt holding down the 'M' button reject the call???
You thinking they could have a case of sticky button? or heavy fingers :)
i dont hold it down i just press it
The M button doesnt seem sticky, works fine apart from rejecting my calls :angry: and no i have a delicate touch :P
Same problem. The manual states that the M (mode) button accepts and rejects calls. If I press M on an incoming call, the call is rejected.
