seb
mk3 fiesta engine head swap
2 posts in this topic
I'm going from a mk1 fez to a mk3 and does anybody kmow if the 1.3 litre head will fit onto the 1.1 litre as i know that the 1.1 were very noisy with the tappets ?
cherz
Not worth it. The 1.3 has the exact same issue. I'm about to go out and grind off the heads to remove the indentation which causes the noise and then set the gaps correctly afterwards. That's pretty much all you can do unless you go to a parts centre and buy them new (looking at around £70 if you do that though).
