seb Posted May 9, 2009 Share Posted May 9, 2009 I'm going from a mk1 fez to a mk3 and does anybody kmow if the 1.3 litre head will fit onto the 1.1 litre as i know that the 1.1 were very noisy with the tappets ? cherz Quote Link to comment Share on other sites More sharing options...
DanFraser Posted May 30, 2009 Share Posted May 30, 2009 Not worth it. The 1.3 has the exact same issue. I'm about to go out and grind off the heads to remove the indentation which causes the noise and then set the gaps correctly afterwards. That's pretty much all you can do unless you go to a parts centre and buy them new (looking at around £70 if you do that though). Quote Link to comment Share on other sites More sharing options...
