Stu@rt
Problems With Programming A New Transponder Key
4 posts in this topic
I have recently purchased a 2010 Fiesta Zetec. It came with two keys, one of which is the three-button remote variety and the other is the basic no-button variety. As far as I am aware they are the original keys that came with the car when it was first sold.
I have a spare three-button flip style key from my old 2006 Focus Sport and was hoping to be able to use this with the Fiesta, so I ordered a blank blade off the Internet and have had this cut to fit the Fiesta.
I have researched online and the common method I found for programming a new transponder key with two already programmed keys is as follows:
  1. Insert the first already programmed key into the ignition, turn it to position II and wait for the warning light to go out
  2. Turn back to 0 and remove the key
  3. Insert the second already programmed key into the ignition, turn it to position II and wait for the warning light to go out
  4. Turn back to 0 and remove the key
  5. Key programming mode is now activated and you have ten seconds to:
  6. Insert the new unprogrammed key into the ignition, turn it to position II and wait for the warning light to go out
  7. Turn back to 0 and remove the key
  8. Allow 10 seconds to pass for the system to exit programming mode.
I have tried this a few times but with no success. When I get to step 6 and turn the unprogrammed key to II the warning light just flashes rapidly and does not go out. It doesn't appear to be recognising the transponder chip in the key for some reason.
Does anyone know what could be causing this? Does my 2010 Fiesta use the same type of transponder chip as my old 2006 Focus?
I have also tried to just swap the transponder chips as a simple solution, but the one in the remote key that came with the Fiesta doesn't want to budge. I've tried to remove it somewhat gently with a pair of pliers but I'm concerned that I'll damage it.
Any help or advice will be gratefully received!
The ability to self programme keys was discontinued on cars built after 2004.
You need someone with an IDS interface to add keys via the data (OBD) port which will take about 5 minutes tops.
Ring around a few local Auto Locksmiths for quotes.
As the key is already cut to match the locks you'll save a few quid, so expect prices around the £40 mark.
DO NOT GO TO FORD!
They will refuse to use your key and charge you stupid amounts plus insisting on a pointless diagnostic on top.
Thanks for the advice! I should have known it wasn't going to be that simple. As it happens I do know of an auto electrician as my old Focus only came with one key and so rather than paying Ford £150 (by recollection) for an another, I ordered two pre-cut keys off the Internet with transponder chips and then got them programmed for £50. I did have to order the 433mhz remotes from China, as at the time I couldn't source them in the UK, but all in all it cost me £120 for two flip-style keys. Two for less than the price that Ford wanted for one!
Ford also quoted me £180 to fix the bonnet lock on my Focus (£100 labour plus £80 parts) but a local mechanic fixed it for £20 labour with no parts needed.
So as you can tell I'm not in a hurry to let Ford part me with substantial amounts of my hard earned cash, lol!
I go to Ford only when I need a rare part.
99% sourced from ebay :d
