Linda
Hub Nut Torque setting
Hi all, My first posting on this forum. My hubby has just looked at the rear brake shoes on my lkle green Fiesta 51 reg, since I complained about a squeeking nose - they are ok luckily.
He now needs to put the central hub nut back on and the Haynes manual says it needs 199 lbft (270 NM) of torque. He says this is a lot? :o is this right? He also says he is gona have to buy a new torque wrench since his only goes up to 150 NM
I searched the web and have seen a quoted figure of 235nm in a couple of places. He says the nut consists of a washer and 4 thin nuts all caged together (30mm socket fits it)
Can any one confirm the value?
Cheers Linda
Cheers Linda
the nut is made up of layers, and should only be used a maximum of 2 or 3 times. 270Nm sounds like far too much, 235 sounds about right, thats also the torque setting for the rear drums on my focus if i remember correctly.
235Nm is bang on
235Nm is bang on
:P Thanks Gaz, Much appreciate your confirmation - I'll tell him indoors to set it to 235NM
Regards, and have a fine day
Thanks Stef :P Much appreciate your response and confirmation - you know what its like when you give a man a big tool, he just wants to use it to its full extent :o
steady on there linda :P :lol::lol:
glad we were able to help you out, or more your husband? :lol:
hi i used to use a 30mm socket but the garage have changed it to adiffrent size now i have to buy a new socket 41mm i think
