ljono27
Imobilzer Stuck On
2 posts in this topic
After flat battery my imobilzer is stuck on giving the code 15 I live in dl15 area and I need a reprogramme can anyone help please
Code 15 - Wrong transponder key
It sounds like your PATS system has forgotten your key transponder code.
You should first of all get a diagnostic done to confirm the problem and then depending on the results then look for a local Auto Locksmith that will recode your key(s) to the car.
Do you only have one key?, if not do none of your keys function?
