AdBlock Warning
sonic113
What Oil Is Best?? 1.6 Zetec Petrol Service Help
15 posts in this topic
Im looking to service the family cars soon they are:
Ford Focus 2009 1.6 Zetec with 66000 on clock.
Ford CMax 2010 1.6 Zetec 40000 on clock
can someone suggest the best oil to use.
I was going to go with Ford formula F 5w30 fully synthetic or Castrol magnatec 5w30 fully synthetic?
Also should I stay with Fully Synthetic or semi synthetic. The guy at the auto parts store adised to stick with the Ford spec 5w30 Fully Synthetic. Just wondering what you guys think or any one with the same engines what you use in your cars.
also if the fuel filter to be replaced on these models I read somewhere that its non serviceable but just want to check.
also My service check list is as follows
- Oil
- Oil Filter
- Spark Plugs
- Air Filter
- Pollen/Cabin Filter
- Fuel Filter (If its serviceable)
if i have forgot anything let me know.
Hello Jabber. I work at a Motor Factors so hopefully can help you out a bit! You are right, the Fuel Filter on both vehicles is what they term a 'Lifetime' filter, hence we have no listing for it. As far as the oil goes, 5w30 is the correct oil grade for both vehicles and it doesn't really matter if it's Semi- or Fully Synthetic. Fully should work a bit longer before breaking down but it more depends on what you can afford!! As you have two cars to do you might opt for a cheaper oil but just make sure it's a 5w30 grade and you should be okay! Some people get caught up with spending mega-bucks on ''name brand'' oils when a decent oil of the same grade usually does just as well!!
Anyway hope that helps you decide. I can't think of anything else you should change.
Have fun,
Chris
It would be the ford stuff of castrol magnatec for me, Can anyone confirm if they are the same stuff? Last time I checked the ford stuff it wasn't that expensive either for a change!
i usually buy this ..theyre about 2 mile from me but charge double this price if i get it over the counter ..when i queeried it they said get it off ebay then .. does'nt make sense
http://www.ebay.co.uk/itm/Genuine-Ford-5W30-Fully-Synthetic-Engine-Oil-5-Litres-1502266-50-OFF-/160881010422?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item25754166f6
WSS-M2C-913-B or WSS-M2C-913-C (C being a newer and better mix, compatible with engines requiring A or B )
Castrol Magnatec Fully Synthetic 5w-30 A1 (913-A/B/C) http://www.opieoils.co.uk/p-754-castrol-magnatec-5w-30-a1-fully-synthetic-engine-oil-recommended-by-ford.aspx
Mobil Super 3000 X1 Formula FE 5W-30 (913-C) www.opieoils.co.uk/p-69360-mobil-super-3000-x1-fe-5w-30-fully-synthetic-engine-oil.aspx
I personally tried out Shell AF HX7 5w-30 in my last oil change which is quite decent too, and the cheapest £17 for 5l bottle http://www.eurocarparts.com/ecp/c/Ford_Focus_1.8_2005/p/car-parts/car-lubricants-and-car-fluids/lubricant-and-fluids/engineoil/?521772231&1&ca5c2f66a77874f24a6e1f721b9086ba7fd4b68b&000398
those are the three id recommend, you'd probably find cheaper prices if you go to other websites, but just showing you the bottles id recommend. i havent tried the Ford Formula FE so i cant comment on that
Ford now use shell oil in there services so ford oil will be rebranded shell
Thanks the reply.
could i use any of the following :
http://www.amazon.co.uk/Ford-Formula-Litres-Fully-Synthetic/dp/B007NZ31Q0/ref=sr_1_2?ie=UTF8&qid=1395312912&sr=8-2&keywords=ford+oil
or
http://www.amazon.co.uk/Castrol-Magnatec-5W-30-Engine-Oil/dp/B0042EUI16/ref=sr_1_1?ie=UTF8&qid=1395313010&sr=8-1&keywords=ford+oil
also wheres the best price for oil/cabin/air filters??
where the spark plugs are concerned what is the best make/type of plug to use and also what gap shoul it be set to?
Thanks again everyone for the replies.
Jabber your not listening are you lol :ph34r:
Use the best you can afford. Its the blood of the engine :-)
Jamie :ph34r:
ok budget way i can go with
ford oil 5w30 formula f
or
castrol magnatec 5w30
just want to know which is best or are they as good as each other?
the only good thing is the ford formula f is 5 ltrs where s the castrol is 4ltrs
just want to do a good service on the car with decent oil so I thinks its gonna be one of the above. I favour the ford formula F as is it not what ford use when the car is left in for a service but just would like your opinion.
Thanks again.
also whats the best spark plugs to go for?
the ford formula f is made by castrol mate and rebranded so they are basically the same oil plugs will be kgk iridium or bosch super plus as standard
I use the mobil fully synthetic one and is really good
Sent from my iPad using Ford OC mobile app
Not all ford oil is castrol unless it says on it u will no castrol because it's green in colour but if u ask me u be better use reasonable price oil an change oil every 6 months least
ford formula f is made by castrol and rebranded its a bp petroleum product who make castrol oil just like all ford stuff is, comma make halfords brand oils
it wont say castrol on it it will be bp petroleum who make castrol and ford oil the colour is down to additives so it wont necessarily be the same colour either
Yeah I agree with u art I just sayin I use get oil in grey can couple years ago off ford now they seem sell it in green can wit castrol on front an has green dye in
theyre always changing it was bp now its shell they deal with but the old stock is still castrol new stock will be shell inside maybe shell pay more god knows lol
