Help anybody.
#1
Posted 17 March 2008 - 11:28 PM
The clutch is whining when I depress/touch the pedal.There is some slack in it also. It also seems whiny at the opposite end.A bearing or alternator maybe? Regards the clutch end might it be the thrust bearing or possbly not set up right when the swap done?
Thanks,
H
#2
Posted 03 April 2008 - 11:55 AM
#3
Posted 17 April 2008 - 04:15 PM
#4
Posted 29 April 2008 - 05:44 PM
Has it got the GTI box or the van box. Apparently you can use the van box if you make an adaptor plate, someone i know used the van box and had problems using the clutch. Mine has the GTI box and i have no problems with it whatsoever.
Hello,
Sorry I havent replied earlier,been out of the country.I dont know what box it has,is there a specific number or way of telling?
I am planning to fit a RS2000 with box into it soon and so I just want to be safe in the short term.
That begs another question,do I need RS2000 ECU.The van has the GTi ECU+ transponder pats which flashes the indicators when you lock it (with the key) . I am sick of Fords and all the different types of anti theft gear,its a minefield to me the uninitiated.
I am fairly sure the GTi ECU wont be perfect for fuelling but will it get it running? Can it be re mapped to mimic the RS200 type?This would seem the best way if its possible owing to the alarm setup.I can get a non pats RS200 ECU,would this work do you think?
#5
Posted 12 May 2008 - 12:21 AM
Hello,
I'm not 100% sure on that side of things. Best bet in an ideal world would be to swap everything to be honest. At least you know then everything should be right
