ford focus TDCI - diagnosis help
1 reply to this topic
#1 luk
luk
    Newbie
  • Pip
  • 6 posts
  • Ford Model: ford focus tdci 115
Posted 12 May 2009 - 11:39 AM
Hi posted earlier about a blown turbo,
The thing is -
Would the car idle over ok and rev ok when parked up if a valve was bent or a conrod bent ?
would it be struggling all the time and not just when driving ?
and is there a test i can do , such as compression testing ?
thanks
also - if a valve was bent how easy is it to change a valve ? once i have the head off (im fine with taking head off)
i did work at a garage for a couple of years and remembed grinding a valve in with the paste and stick
#2 jasmeet
jasmeet
    Member
  • PipPip
  • 13 posts
  • Ford Model: focus '06 1.8tdci
Posted 29 May 2009 - 10:59 AM
i wouldnt advise driving the car or starting the engine for that matter
get it checked out asap
the work itself (valve) isnt too bad, just the labour incurred, takes a while to do the work
bent conrod? not sure about that as ive only done valve work once, never gone that far before
