Number Plate Bulb Issue
BryzeMo
Hi
My electrical troubles continue!! I havent had a chance to fix my number plate bulbs yet from a previous post but was driving the car tonight and i now hav no intrument cluster lights on my speedo, rev counter, heater knobs etc?? I know these are all linked by the same fuse but checked this 7.5a fuse and is ok. Any ideas whats going on here?
Bryan
  • 1 year later...
Hi I was reading your post about your number plate light , and dash lights not working ,My son has the same issue
reading your notes did you have to take the fuse box out to replace the damaged / loose wire from the fuse box
thanks
If, as you say the fuse is ok I suspect an earthing issue and / or a bad feed somewhere on the dash illumination circuit
  • Like 2
Agreed with Mark.
Check the earthing points.
When you turn the lights on and the engine running, is the headlight lightly flickering? that could indicate a bad alternator, or battery, which is worth checking at this time of year. I would then check the earth point next to the battery, clean it up and resecure and see if this improves the situation. If not, then you would certainly need to check the other earth points, one I believe is on the gearbox, others are on the body of the car.
