Mk2 Focus Sport Temperature Problem
jg1581
 Share
Hi all please please please help me, my engine temp will not go beyond 60c I changed the thermostat TWICE and coolant temp sensor, there are no fault codes and the are no leaks, the oil is fine and as far as I can tell the water pump is pumping so has anyone any ideas
Link to comment
How are you reading the temperature, via ODB or the instrument cluster.
Just trying to think if it might be a display issue, rather than sensor?
Link to comment
Run the car in test mode by holding the set/reset on the trip computer while you turn the ignition to the on position (not starting the car), then use the set/reset button to cycle through the menus until you reach the Engine Temp screen.
the temperature on the dials is the coolant temperature sensor and that will not rise as fast, only when you drive for some time it will start to rise.
Link to comment
Im reading the temp from the dials on the dash aswell as via odb linked to my phone and it reads the same temp as for the trip counter thing I shall give that a whirl
Link to comment
Theres a head temp sensor and a coolant sensor plugged into the side of the thermostat
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
