smiler
Parking Sensors... Long Tone?
9 posts in this topic
i have a zetec 2006 and when i put the car in reverse instead of my usual beeping tone ,i am getting a long tone for 3 seconds.i have read other forums and it states there is a problem with one or all the sensors ,has anyone had this issue .
regards
would agree most likely culprit is a faulty sensor
If u stick ur ear up to each sensor individual u can usually hear same noise this give u an indication
Look to see if the paint is bubbling on any of the sensors.
And many owners get this issue when it rains - see if it clears up in the dry.
Check for harness/wiring integrity in the rear.
I had this, plugged in diagnostic. it told me it was the front NS inner sensor. So i swapped it with the inner offside sensor and the diag still told me it was on NS inner. So we know the sensor is good. This left me with the wiring. I physically started to check cable and connectors from the sensor and found a broken cable where it ran behind the lower front grille.
Can't quite remember but on the drivers front wing from the engine bay i removed the headlight and under that is a multi connector with all the front sensors going to it. I used a continuity tester to test the each cable individually from this connector to the sensor.
You do need to have a diagnostic to tell you which sensor is the problem, i used the ELM327 device.
I have the same problem, only since my battery was disconnected, so do I disconnect my battery again to see if this will work
worth a try?
make sure you know your code to the stereo.
Its quite often the looms front / rear. Not expensive & easy to replace
