hardyhardy Posted March 30, 2014 Share Posted March 30, 2014 Hi all, went out for a fast spin and tried some hard braking on my Mk3... I can feel a sort of rapid vibration/judder when I do this but its not noticeable at 'sensible braking' speeds. lol Is this a symptom of warped disks? Or tracking? The guy I got it off claims it had new brakes fitted 6 months ago, so not sure whats going on. Tyre wear seems even though Any inputs most welcome! Quote Link to comment Share on other sites More sharing options...
Nighthawk Posted March 30, 2014 Share Posted March 30, 2014 Do you get vibration in the steering or pedal? If the discs/pads are fine it may be the abs kicking in. Sent from my HUAWEI Ascend P2 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
gurcayy Posted March 30, 2014 Share Posted March 30, 2014 It looks like warped discs. Usually, even the new discs, especially not OEM ones, tend to warp and they need to be grinded on a lathe or machine designed for this. It is also possible to warp the discs if you get through a water after extended use of the brakes. Quote Link to comment Share on other sites More sharing options...
hardyhardy Posted March 30, 2014 Author Share Posted March 30, 2014 Do you get vibration in the steering or pedal? If the discs/pads are fine it may be the abs kicking in. Sent from my HUAWEI Ascend P2 using Ford OC mobile app Hi yes i feel it in the peddle mostly. But then again, the sterring does feel a bit stiff!! Turning left anyway, maybe I should check tyre pressures Quote Link to comment Share on other sites More sharing options...
hardyhardy Posted March 30, 2014 Author Share Posted March 30, 2014 It looks like warped discs. Usually, even the new discs, especially not OEM ones, tend to warp and they need to be grinded on a lathe or machine designed for this. It is also possible to warp the discs if you get through a water after extended use of the brakes. Cheers, I dont mind replacing them, but how can I tell if they are warped for sure? Jack up and rotate wheel or something? Quote Link to comment Share on other sites More sharing options...
mintalkin Posted March 31, 2014 Share Posted March 31, 2014 with the wheels removed the runout on the discs can be checked with a dial gauge, it should also be used when fitting discs to ensure the discs are bedded right before use. Quote Link to comment Share on other sites More sharing options...
