AdBlock Warning
wilkinsj93
Ford Focus 1.6 Headlights Dim When Bass Hits
5 posts in this topic
Hi All. Im new to the forum. not sure if anyone can help me.
I have a 55 plate 1.6 ford focus.
now everytime I turn my radio up and the bass hits the lights dim (headlights, odometer light)
now this is what I have installed at present
105a brand new ford original alternator
a brand new 72ah battery silver calcium ford original
done the big 3 wire upgrade
cleaned up the grounds in boot, headlight earth, and main earths
I have a jvc head unit
A FLI 900S 4 channel amp in 2 channel mode bridged with a 12" edge sub connected to it
if anyone could shed any light on the situation.
would be gratefully appreciated.
This is a classic Audio problem.
The current draw is higher when the Bass audio is kicking in. There is a easy thing to sort.
I would suggest a Power CAP on the power input to the Amplifier. There are tables that will say what value is required.
But I would suggest a 1Farad cap should do the trick.
These are not that expensive, but go for a good make Cap as the cheaper ones are a little pony and not true to the value.
If I can suggest a retailer, I have worked close with Gavin at G7 Sounds. These guys know the products and trade.
You can say you spoke to JustConnect and they may do you a good turn.
http://www.g7sounds.co.uk/
Cheers
Hi (just connect)
I have been told that installing a cap will only make things worse. Im going to see my local audio speaialist at weekend to see what they have to say. But thanks anyway. :D
What size cable did you use for the big 3?
