stanley Posted April 6, 2014 Share Posted April 6, 2014 hi all hope someone can help horn not working on my y reg focus. I can here a tick noise from passenger side but cant find the fuse box there. fuse not mentioned under the bonnet so a bit stuck any help any clues many thanks stan Quote Link to comment Share on other sites More sharing options...
BigD Posted April 6, 2014 Share Posted April 6, 2014 It's behind the glovebox, and the ticking noise will be a relay opening/closing. Empty the glovebox, then close it up. Look underneath and you'll find three screws. Take them all out, then open the glovebox, push the sides inwards and the whole thing will come out. (You don't HAVE to remove it fully, you can just drop it down without taking the screws out, but for the 60 seconds it takes to do it, you'll get much better access). Oh, there's an engine bay fusebox too. If memory serves it's right at the back corner of the engine bay, on the passenger side and nearest the windscreen. What problem are you having? What are you hoping to find in there? 1 Quote Link to comment Share on other sites More sharing options...
stanley Posted April 6, 2014 Author Share Posted April 6, 2014 hi big d many thanks im in there now horn not working so fuse to change first stan Quote Link to comment Share on other sites More sharing options...
BigD Posted April 6, 2014 Share Posted April 6, 2014 Hi again - assuming the fuse checks out OK you might want to take a look at the clock spring (which is an air-bag/steering wheel off job). Tho saying that, could be the horn itself is dead, if you're hearing the relay opening/closing. Quote Link to comment Share on other sites More sharing options...
stanley Posted April 7, 2014 Author Share Posted April 7, 2014 Thanks big d. Will pop down garage to see mechanic pal who will have spare horn before steering wheel off task. Many thanks stan Sent from my GT-I9300 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
